estop-out is not following the E-Stop status
3 years 2 weeks ago #282805 by ruffle
Thanks for that pointer (wouldn't have found it in a million years!)
hauli.estop.is-activated does indeed follow the E-Stop state as you say.
However, I can't get it to turn the output on my 7i76E on :-(
net hauli.estop.is-activated => hm2_7i76e.0.7i76.0.0.output-05
doesn't actually change output 5 on when hauli.estop.is-activated changes. I'm using the same constructs for other 7i76E outputs (net pause-on => hm2_7i76e.0.7i76.0.0.output-06) and they work.
I'm missing something obvious but I'm in danger of wearing out Mr Google trying to find it :)
3 years 2 weeks ago #282806 by phillc54
You forgot a name for the net:
net estop-active hauli.estop.is-activated => hm2_7i76e.0.7i76.0.0.output-05
3 years 2 weeks ago #282815 by ruffle
I think that was one of the permutations I tried while flailing around but it results in an error:
Putting this in Test.hal:
Linuxcnc errors out with:
./Test.hal:28: Pin 'hauli.estop.is-activated' does not exist
3 years 2 weeks ago #282816 by tommylight
Typo, should be "halui"
net estop-active halui.estop.is-activated => hm2_7i76e.0.7i76.0.0.output-05
3 years 2 weeks ago #282820 by ruffle
Arrrrrrgh! I *hate* it when I do that!!!! :-( :-( :-(
Surprisingly it works when you type the correct thing!
Many thanks to all. Now fully working.
3 years 2 weeks ago #282840 by phillc54
Haha, that is embarrassing, I need to learn how to read correctly...
Time to create page: 0.062 seconds
