mesaCT, 7i95t and SPINx
- DK8DE
- Thank you received: 4
22 Jan 2024 17:54 - 25 Jan 2024 21:53 #291351
by DK8DE
mesaCT, 7i95t and SPINx was created by DK8DE
Hello,I'm new to LinuxCNC and come from an electronics background, with good familiarity in C. I installed the MesaCT tool and managed to get the three steppers for XYZ working. However, in the spindle tab of the tool, I can't select anything; all buttons are greyed out. I would like to connect the SPINx to channel 5, where I assume the PWM signal is. What settings do I need to adjust in MesaCT to implement this? Writing the .hal file still confuses me a bit. Does anyone have a sample configuration, or can anyone advise what settings I need to adjust in MesaCT to get the spindle running?
Best regards, Jörg
Edit:
On channel 5, the Dir signal switches with the change of direction, but I don't have a PWM output on Step. I have attached the configuration.Best regards, Jörg
Best regards, Jörg
Edit:
Last edit: 25 Jan 2024 21:53 by DK8DE.
- DK8DE
28 Jan 2024 16:10 #291814
by DK8DE
Replied by DK8DE on topic mesaCT, 7i95t and SPINx
Problem has been resolved. Here are the parts from the INI and HAL:
#### INI
[SPINDLE_0]
TYPE = pwm
PWM_TYPE = 1
PWM_FREQUENCY = 5000
SCALE = 24000
#### HAL
# hostmot2 driver
loadrt hostmot2
loadrt [HM2](DRIVER) board_ip=[HM2](IPADDRESS)
setp hm2_[MESA](BOARD).0.watchdog.timeout_ns 5000000
# THREADS
addf hm2_[MESA](BOARD).0.read servo-thread
addf pid.0.do-pid-calcs servo-thread
addf pid.1.do-pid-calcs servo-thread
addf pid.2.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf hm2_[MESA](BOARD).0.write servo-thread
# Spindle Connections
net spindle-vel-cmd <= spindle.0.speed-out
net spindle-vel-cmd => pid.s.command
net spindle-pid-out <= pid.s.output
net spindle-pid-out => hm2_[MESA](BOARD).0.pwmgen.00.value
#Spindel
# Spindle PWM Setup
setp hm2_[MESA](BOARD).0.pwmgen.00.output-type [SPINDLE_0](PWM_TYPE)
setp hm2_[MESA](BOARD).0.pwmgen.pwm_frequency [SPINDLE_0](PWM_FREQUENCY)
setp hm2_[MESA](BOARD).0.pwmgen.00.scale [SPINDLE_0](SCALE)
# Spindle Feedback
setp spindle.0.at-speed true
# Spindle Command Pins
net spindle-on <= spindle.0.on
net spindle-on => pid.s.enable
net spindle-on => hm2_7i95.0.ssr.00.out-00
net spindle-cw <= spindle.0.forward
net spindle-ccw <= spindle.0.reverse
net spindle-brake <= spindle.0.brake
# Spindle Enable
net spindle-on => hm2_[MESA](BOARD).0.pwmgen.00.enable
# standard components
loadrt pid names=pid.0,pid.1,pid.2,pid.s
#### INI
[SPINDLE_0]
TYPE = pwm
PWM_TYPE = 1
SCALE = 24000
#### HAL
# hostmot2 driver
loadrt hostmot2
# THREADS
#Spindel
# Spindle PWM Setup
# Spindle Feedback
# Spindle Enable
The following user(s) said Thank You: JT, Sbvr4, Sergiy_J_S_Automatic
- Sbvr4
30 Jan 2024 15:45 #291988
by Sbvr4
Replied by Sbvr4 on topic mesaCT, 7i95t and SPINx
Hi Jorg,
How did you go about solving the issue? I am experiencing the same problem.
Thank you,
Sean
Thank you,
Sean
- Sergiy_J_S_Automatic
28 Feb 2024 19:18 #294715
by Sergiy_J_S_Automatic
Replied by Sergiy_J_S_Automatic on topic mesaCT, 7i95t and SPINx
Your configuration files helped me. I suffered with this problem for 2 weeks.
28 Feb 2024 19:20 #294717
If you haven't solved your question, I can try to help.
- DK8DE
29 Apr 2024 16:34 - 29 Apr 2024 16:36 #299325
by DK8DE
Hello,All my issues are resolved. The spindle is running, and the end stops and stepper motors are also functioning. For those looking for an example, I have attached the files.
Last edit: 29 Apr 2024 16:36 by DK8DE.
- Hastrh2o
- Thank you received: 6
11 Jun 2024 22:57 #302853
by Hastrh2o
Replied by Hastrh2o on topic mesaCT, 7i95t and SPINx
I'm configuring a kind of lathe with one 5i25 and two 7i77 and I'm facing the same problem : in the spindle tab of Mesa CT, I can't select anything; all buttons are greyed out.
Where does it come from ?
Jôrg, did you terminate the configuration by hand or with Mesa CT? You did'nt explained what's wrong with your spindle tab.
I've another problem with analog outputs but I just saw Peter's answer (forum.linuxcnc.org/24-hal-components/528...how-and-is-not-found) so it should be ok. In case it would be related... I would try it tomorrow.
- JT
- Thank you received: 593
12 Jun 2024 21:22 #302905
by JT
Replied by JT on topic mesaCT, 7i95t and SPINx
Thanks for posting the files, I'll incorporate that into Mesa CT as soon as possible.
JT
JT
- AirRacer
- Thank you received: 3
13 Jul 2024 21:27 #305109
by AirRacer
Replied by AirRacer on topic mesaCT, 7i95t and SPINx
How was this resolved? I'm using MesaCT v 2.1.4 to configure 7i97T+7i76 and I also have a spindle tab with all option grayed out. I'm planning to use the TB4 spindle output output on 7i76.
Time to create page: 0.182 seconds
