Mesa 7i95t and 7i83 Analogue servo card
01 May 2024 18:04 #299486 by NT4Boy
Replied by NT4Boy on topic Mesa 7i95t and 7i83 Analogue servo card
I have my Raspi5 booting from SSD, and very impressed with its speed.
Have installed the current mesact 2,1,3, and it finds my 7i95T, but 7i83 isn't in the pull down.
So selected 7i77 as the daughter board, and get a PI 7i77 tab and can put enough numbers in an X axis setup to be able to save the config.
Starting Linuxcnc, and calling my minimal config errors with :-
./main.hal:211:Pin 'hm2_7i95.0.7i77.0.4.analogout3'
The advice above is to manually edit the configurations files and change the references from 7i77 to 7i83,
Editing the reference in the 7i95t_XYZ.ini, doesn't result in the mesact 7i77 tab being renamed, and there are dire warnings that manually editing the main.hal will result in mesact overwriting and otherwise ignoring.
When I do manually edit the two files and replace all 7i77 references with 7i83,
I get nominally the same error.
./main.hal:211:Pin 'hm2_7i95.0.7i83.0.4.analogout3'
I assume therefore that the 7i83 has some other way to refer to its 'things'.
halcmd show all  with both cards powered and connected linuxcnc running in demo mode shows a lot of data, but
halcmd show all hm2 shows nothing, so I am stuck.
I need some very baby steps  please,
01 May 2024 18:15 - 01 May 2024 18:19 #299487 by PCW
Replied by PCW on topic Mesa 7i95t and 7i83 Analogue servo card
The command would be:
halcmd show all | grep 7i83
(While LinuxCNC is running)
You can also use halshow to look through the pin and parameter trees
Last edit: 01 May 2024 18:19 by PCW.
01 May 2024 18:21 #299489 by NT4Boy
Nope, still nothing.
I am running linuxcnc axis sim, is that enough to get access to these cards from the halcmd?
01 May 2024 18:26 #299492 by PCW
No
01 May 2024 18:26 #299493 by NT4Boy
Ok, got it.
I have to edit the hal file to comment out the analog lines.
Then I can call the config without the error, and now I get grep 7i83 data.
Not sure what to do with it....!
01 May 2024 18:31 #299494 by PCW
You can use the 7I83 pins and parameter names to verify the correct names in your hal file
You can even copy/paste them from a file created with:
halcmd show all | grep 7i83 > 7i83.txt
The following user(s) said Thank You: NT4Boy
01 May 2024 18:36 #299495 by NT4Boy
Exactly. I've printed it already..
That's a huge step for me, thanks for your patience.
So I guess, that I need to go back to mesact, call up the 7i77 again, enter as much machine info as I can for all axes and the spindle, and from then on I am away from that GUI and into text.
08 May 2024 09:01 #300097 by NT4Boy
In mesact, with the 7i95 and 7i77 cards chosen, I am confused with encoder setup.
The 8i83 has no encoder terminals, so I'll connect those to the 7i95.
In the 7i95 tabs I guess I have to set say an X axis and can configure an encoder scale etc, but I also have to setup the 7i77 tab for another X axis for the analogue PID. (There is also an encoder tab in the 7i77 setup but don't understand why).
(Yes I know the 7i77 refs will need updating to 7i83 in due course)
But my question is how does anything know not to generate steps.
I cannot immediately see a way to disable the step gen and pid on the 7i95 as the config doesn't check out if I leave those fields blank.
Maybe, if there is an analogue channel set, step settings are just ignored?
I'd appreciate some clarification. Thanks
08 May 2024 10:06 #300104 by tommylight
Replied by tommylight on topic Mesa 7i95t and 7i83 Analogue servo card
Open a hal file in a text editor, have a look through it, you see there are:
-loadrt < loads real time components like stepgens, pwmgens, encoders, logic, custom components, etc
-addf < add function (probably) adds those components to servo period or base period or a custom period, so they are run at a set timing
-net < it literally is wire a pin to another pin or many other pins, consider those pins as wires
-setp and sets < set values for parameters and signals
08 May 2024 11:09 #300109 by NT4Boy
Thanks.
I'll have to read the HAL reference some more to get a handle on how the syntax works as I haven't clicked with it and all the fields.
Cannot see any pins, so stumped by that.
There are net commands for example:-
net joint-0-index-enable <=> pid.x0.index-enable
net joint-0-index-enable <=> joint.0.index-enable
net joint-1-index-enable <=> pid.x1.index-enable
net joint-1-index-enable <=> joint.1.index-enable
joint 0 is X axis on the 7i95t and joint 1 is X axis on the 7i77
I don't know if that's wrong or right or makes any sense....
A lot more reading to do.
Time to create page: 0.395 seconds
