- Thank you received: 8
7i73 8x8 matrixkey how to map number
- abdulasis12
2 years 5 months ago #300045
by abdulasis12
7i73 8x8 matrixkey how to map number was created by abdulasis12
I just use 7i73 first time .
Now I use 8x8 mode keyscan its work !
I use pendant its great!!
I link customGUI Gmoccapy its run good.
Now I use about 30 scankey I have free key about 30 key.
- I want map scankey to number 0-9 for type in MDI mode
- I want map some word for 1 scankey press... example , "M6 T" (I don't know its can or not .)
- I want map some button on keyboard "delete" , "Enter" "leftkey" , "rightkey"
How to do it ?
Thank you,
Asis
How to do it ?
Thank you,
Asis
- COFHAL
- Thank you received: 62
2 years 5 months ago - 2 years 5 months ago #300084
by COFHAL
Replied by COFHAL on topic 7i73 8x8 matrixkey how to map number
Yes, To simulate keyboard keys use the scancode component
linuxcnc.org/docs/html/man/man1/sendkeys.1.html
Last edit: 2 years 5 months ago by COFHAL.
The following user(s) said Thank You: abdulasis12
- abdulasis12
2 years 5 months ago - 2 years 5 months ago #300136
by abdulasis12
Replied by abdulasis12 on topic 7i73 8x8 matrixkey how to map number
Yes, To simulate keyboard keys use the scancode component linuxcnc.org/docs/html/man/man1/sendkeys.1.html .
Thank you for fast reply MR. COFHAL
I read in link but still confused about the variable format.
I tryCode:sudo groupadd -f uinput sudo gpasswd -a (myuser) uinput create file on your location 99-input.rules sudo echo KERNEL=="uinput", GROUP="uinput", MODE:="0660" | sudo tee /etc/udev/rules.d/88-input.rules and restart
Try , ls -l /dev/uinput
result : (its have respond result but not sure I forgot take photo and now back home)
[/code]Code:I try add this in main hal file[code]loadusr -W sendkeys config=s64t10 net scancodes hm2_7i96s.0.7i73.0.3.keycode => sendkeys.0.keycode setp sendkeys.0.scan-event-00 34 # Key G setp sendkeys.0.scan-event-01 2 # Key 1 setp sendkeys.0.scan-event-02 3 # Key 2 setp sendkeys.0.scan-event-03 4 # Key 3 setp sendkeys.0.scan-event-04 50 # Key M setp sendkeys.0.scan-event-05 05 # Key 4 setp sendkeys.0.scan-event-06 06 # Key 5 setp sendkeys.0.scan-event-07 07 # Key 6 setp sendkeys.0.scan-event-08 31 # Key S setp sendkeys.0.scan-event-09 8 # Key 7 setp sendkeys.0.scan-event-10 9 # Key 8 setp sendkeys.0.scan-event-11 10 # Key 9 setp sendkeys.0.scan-event-12 20 # Key T setp sendkeys.0.scan-event-13 11 # Key 0 setp sendkeys.0.scan-event-14 52 # Key Dot setp sendkeys.0.scan-event-15 14 # Backspace setp sendkeys.0.pin-event-00 29 # Left Ctrl setp sendkeys.0.pin-event-01 57 # Space setp sendkeys.0.init 1
I try open linuxcnc , can boot up.
I powerOn and change to MDI mode and click in space MDI.
I try use Keyboard can type in MDI , I try press all in matrixkey (64keys) , not any respond in MDI
how can I check correct or wrong about setup ?
I have question , If I want key.r5c5 from matrixkey to map Key G how to setp ?[/code]Code:[code][b] [/b]
Last edit: 2 years 5 months ago by abdulasis12.
- abdulasis12
2 years 5 months ago #300181
by abdulasis12
- COFHAL
2 years 5 months ago #300183
by COFHAL
I have configured my 7i43, one part with the matrix_kb component that generates pins, which I use with halui to connect them to external buttons and another part I use with the sendkeys component to simulate keyboard keys. If you want to know if sendkeys is working, run LCN from the console and there you will be able to see if pressing any button is reflected in the console. Tomorrow I will share my configuration with you.
- COFHAL
2 years 5 months ago #300184
by COFHAL
Time to create page: 0.690 seconds
