motion.spindle vs spindle
- vre
- Thank you received: 17
11 May 2024 08:05 #300376
by vre
motion.spindle vs spindle was created by vre
I have 2 spindles in my mill 1 to z axis 1 to y axis iso40 taper that have sensor for tool detection and hydraulic electrovalve for locking tool.
Also each spindle has gearbox with 2 positions
with sensor in which position is and hydraulic electrovalve for changing gears to position 1 or 2.
I plan to use encoders on spindles for rigid tapping.
The spindles can't driven together because there is only 1 inverter and selection which spindle will work is done via 3 phase relay.
Inverter gets -10v +10v analog input and enable signal.
real time splindle hal component supports gears but motion.spindle not.
Which component must use spindle or motion.spindle?
pncconf by default setup in config motion.spindle how can use gears 1 and 2 for motion.spindle?
- Thank you received: 4648
18 May 2024 08:30 #300897
Replied by andypugh on topic motion.spindle vs spindle
I don't really understand the question. HAL pins are HAL pins, you can connect them how you like.
The motion.spindle HAL pins were renamed when multi-spindle support was introduced, If you have an older HAL component that expects connections to motion.spindle..... just connect instead to spindle.0....
Time to create page: 0.516 seconds
