MPG Jogging
07 Jul 2024 16:39 #304586 by B.Reilly01
MPG Jogging was created by B.Reilly01
I've gt almost everything working on my mill, but the MPG Jogging...  encoder is ounting but axis is not moving.  I'm sure its simple.  Attached are my hal and ini files.  Thank you.
07 Jul 2024 17:27 #304588 by Aciera
Replied by Aciera on topic MPG Jogging
Have you checked if 'axis.L.jog-enable' is true and what 'axis.L.jog-scale' is set to?
07 Jul 2024 19:03 #304593 by B.Reilly01
Replied by B.Reilly01 on topic MPG Jogging
So it's axis.L.jog-scale is not set - I can force them to set to a static value, but is there a way in Probe Basic to connect it to the GUI increments? If I had room and hadn't already cut the control panel, I'd connect them to a selector switch, but the panel is cut and there's no room for increments. If I need to I can add it outside the control panel (like on the side of the pendant).
Time to create page: 0.315 seconds
