M-codes location
2 years 3 months ago #305350 by eduard
M-codes location was created by eduard
Where are Lcnc M-codes are stored?
I having hard time to run a custom macro in qtdragon_hd since the ini pah of subroutines not working. The macro itself is working. I also read and followed the docs on how to add multiple path to subroutines in the ini.
2 years 3 months ago - 2 years 3 months ago #305354 by eduard
Replied by eduard on topic M-codes location
Here is the part of the doc refering to custom M-codes:"The external program named M100 through M199 (no extension, a capital M, found in directory pointed by [DISPLAY] PROGRAM_PREFIX parameter of the INI file) is executed with the optional P and Q values as its two arguments."I followed this and the lcnc did not find the macro.
the txt must added to post to forum, but not used in lcnc.
Last edit: 2 years 3 months ago by eduard.
2 years 3 months ago #305355 by Aciera
Replied by Aciera on topic M-codes location
Have you set the files permission to 'Allow executing file as program'?
2 years 3 months ago - 2 years 3 months ago #305367 by eduard
Now I set it. Working. Thanks.
But where are the other M codes in the system?
2 years 3 months ago #305368 by Aciera
The built in Mcodes (eg M2, M3, M4, M5) are hard coded in the software, if that is what you mean.
2 years 3 months ago #305373 by eduard
Yes, exactly what I'm looking for. Then if I need to change M6 let say, how can I do that?
Time to create page: 0.206 seconds
