Jogging not working on basic setup
- amitsa
14 Aug 2024 19:08 #307731
by amitsa
Jogging not working on basic setup was created by amitsa
I'm new to LinuxCNC and hobbyist machining. For some reason, jogging isn't working on my 3 Axis setup. I feel like I'm just missing one critical configuration but can't figure it out. I got homing to work from the Axis GUI, but jogging doesn't work.
I've posted my INI files and HAL files. I've only included X axis configurations for brevity. Any tips ?
System Details
* Raspberry Pi 5
* LinuxCNC 2.9.3
System Details
* Raspberry Pi 5
* LinuxCNC 2.9.3
- Thank you received: 7485
14 Aug 2024 19:15 #307733
Replied by tommylight on topic Jogging not working on basic setup
Attach the proper files, what are we supposed to do with crippled files?
- amitsa
14 Aug 2024 19:30 #307736
by amitsa
Replied by amitsa on topic Jogging not working on basic setup
I posted the original hal and INI files. But I'm not sure if there are other files you were referring to.
Right now the files are for a 2 AXIS setup with a pair of Y joints. I'm just trying to get jogging to work for these axis' before adding the Z axis.
14 Aug 2024 19:39 #307738
Now the files are OK, the first round they were redacted and actually had a written line claiming that.
Files seem OK, so it should work, but i know it will not, forgot why as it was a long while ago, but i did manage to get it working, i think, i will have to check the configs of some small machines that only use 2 axis, later.
- COFHAL
- Thank you received: 62
14 Aug 2024 20:30 #307740
by COFHAL
Replied by COFHAL on topic Jogging not working on basic setup
In the file. Ini include KEYBOARD_JOG=1
- Thank you received: 4149
14 Aug 2024 20:51 #307746
Replied by rodw on topic Jogging not working on basic setup
You need to follow the example for a MPG under hardware examples
- amitsa
14 Aug 2024 22:09 #307751
by amitsa
Thanks for the replies. @rodw Is the Gantry Panel example something you had in mind for an MPG ?(github.com/LinuxCNC/linuxcnc/blob/master...try/gantry_panel.hal)
Also I did some more investigation on the issue. I diffed all the pins before and after I click on the jog increment for the X axis. These are the pins that changed:
`motion.jog-is-active` : FALSE → TRUE
`motion.in-position` : TRUE → FALSE.
`joint.0.vel-cmd` : 0 → -0
* The sign changed, even though the magnitude is 0.
`joint.0.kb-jog-active` : FALSE → TRUE
`joint.0.in-position` : TRUE → FALSE
`joint.0.free-pos-cmd` : 0 → -2e+99
* I think clicking on the "continous" selection causes a big number.
`joint.0.free-tp-enable` : FALSE → TRUE
The problem is that I'm only routing `joint.0.motor-pos-cmd` to `stepgen.0.position-cmd`. But after seeing this I realized that maybe I should conditionally route `joint.0.free-pos-cmd` to stepgen, if the free planner (aka jogging) is selected.
- amitsa
14 Aug 2024 22:15 #307753
by amitsa
Is the motion planner (used for G-Code) and free planner (for jogging) two separate components of motmod ?
If so then that might explain why `joint.0.motor-pos-cmd` doesn't change from clicking on the AXISGUI jogging buttons.
- amitsa
15 Aug 2024 20:27 #307836
by amitsa
Nevermind my last 2 comments. The problem was I was not adjusting the jogging velocity slider in the AXIS GUI. Classic example of "not reading the manual" :/
Time to create page: 0.103 seconds
