Homing result in joint on limit switch error
26 Aug 2024 15:40 - 26 Aug 2024 15:40 #308712 by vibram
Hello,
I keep getting the following erro: Joint on limit switch error on my lathe Z axis.
I have a signle switch for homing and Z max.
You can find attached my hal and ini files.here is the procedure:I click on homing Axis Z, the machine in moving against the tailstock, where the switch is, the switch is triggered, the machine comeback a little bit and go again against the switch at lower speed.
When the switch is triggered the second time, I get the joint limit error.maybe you can help me to spot the mistake in my INI file?
Thank you very much
Last edit: 26 Aug 2024 15:40 by vibram.
26 Aug 2024 15:51 #308713 by Aciera
In the [JOINT_1] section try changing this:
HOME_OFFSET = -0.10
to this:
HOME_OFFSET =  0.10
26 Aug 2024 18:09 - 26 Aug 2024 18:10 #308725 by vibram
I have exactly the same result
Edit: with 1.0 instead of 0.10 this is fine. Thanks a lot
Last edit: 26 Aug 2024 18:10 by vibram.
Time to create page: 0.344 seconds
