- Configuring LinuxCNC
- Basic Configuration
- 7i97T with Mesa CT- Desn't seem to be outputting an analogue signal.
- flyingbrick
- Thank you received: 19
13 Oct 2024 00:25 #311907
by flyingbrick
7i97T with Mesa CT- Desn't seem to be outputting an analogue signal. was created by flyingbrick
Hi all.I have taken a look through the forums here and had a heavy google search- I had a few leads but all parts of my code appear OK where others seem to have failed.I was trying to identify if it was my drives not responding to signal, my wiring being incomplete, or my HAL setup.. could be all of them but I am unable to pick up any output from the mesa board via multimeter or drive monitoring software.Please see attached- any assistance very much appreciated.
- Thank you received: 7481
13 Oct 2024 00:55 #311912
Replied by tommylight on topic 7i97T with Mesa CT- Desn't seem to be outputting an analogue signal.
There is nothing regarding spindle in those files, except the ON pin.
Try again or edit this but do check if the spindle stuff is checked in the wizard.
The following user(s) said Thank You: flyingbrick
- flyingbrick
13 Oct 2024 01:03 #311914
by flyingbrick
Replied by flyingbrick on topic 7i97T with Mesa CT- Desn't seem to be outputting an analogue signal.
Correct - there was no way of configuring the spindle using my card and mesa CT - But that was a hurdle to jump another day
it should still work tho right? Or does it NEED spindle??
- Thank you received: 5326
13 Oct 2024 05:01 #311924
Replied by PCW on topic 7i97T with Mesa CT- Desn't seem to be outputting an analogue signal.
When linuxcnc is running and you expect an analog output
can you run:
halcmd show all > all.txt
in a terminal window and port all.txt here?
can you run:
- flyingbrick
13 Oct 2024 05:21 #311925
by flyingbrick
Hi PCW.
Attached. I cant do it while actually trying to generate an output as it errors within a moment due to movement error
- flyingbrick
13 Oct 2024 05:24 - 13 Oct 2024 05:34 #311926
by flyingbrick
edit to clarify.
When i look at halconfig and PWM enable and value,
00 and 01 enable when i turn on the machine within lcnc
I can jog X and get 00 to flash up a value. 01 and 02 do not do this (02 probably because its not enabled)
Last edit: 13 Oct 2024 05:34 by flyingbrick.
- flyingbrick
13 Oct 2024 05:28 #311927
by flyingbrick
Dont know what went wrong with that last one.
13 Oct 2024 14:45 - 13 Oct 2024 14:55 #311971
None of the PWM enables are true (and all PWM values are 0)
So no analog output is possible:
30 bit IN FALSE hm2_7i97.0.pwmgen.00.enable <== joint-0-enable
30 float IN 0 hm2_7i97.0.pwmgen.00.value <== joint.0.output
30 bit IN FALSE hm2_7i97.0.pwmgen.01.enable <== joint-1-enable
30 float IN 0 hm2_7i97.0.pwmgen.01.value <== joint.1.output
30 bit IN FALSE hm2_7i97.0.pwmgen.02.enable <== joint-2-enable
30 float IN 0 hm2_7i97.0.pwmgen.02.value <== joint.2.output
30 bit IN FALSE hm2_7i97.0.pwmgen.03.enable
30 float IN 0 hm2_7i97.0.pwmgen.03.value
30 bit IN FALSE hm2_7i97.0.pwmgen.04.enable
30 float IN 0 hm2_7i97.0.pwmgen.04.value
30 bit IN FALSE hm2_7i97.0.pwmgen.05.enable
30 float IN 0 hm2_7i97.0.pwmgen.05.value
30 s32 OUT 0 hm2_7i97.0.read-request.time
30 s32 OUT 134983 hm2_7i97.0.read.time
Note that on initial setup of analog servos you will need to widen the following error limits
as you will likely trigger an immediate following error with such narrow limits
I would start with say 10 mm for FERROR and MIN_FERROR. You may also find that
you get an instant runaway because the feedback polarity is backwards.
YOu fix the by reversing the sign of the PWM scale
Last edit: 13 Oct 2024 14:55 by PCW.
- flyingbrick
13 Oct 2024 20:20 #312004
by flyingbrick
Thanks tons PCW,
halcmd show all > all.txt is an excellent tool, and your explanations are brilliant.
Its taking me a while to figure out what each item does and what we are achieving but the cogs are starting to mesh in my brain :-D
I might have to finish work early today and do some more digging.
Thanks again,
Thanks again,
- flyingbrick
13 Oct 2024 21:05 - 13 Oct 2024 21:09 #312006
by flyingbrick
Hi PCW.
I believe I have found an error in the mesaCT's hal file... but I could be wrong (I have just been comparing axis and trying to figure out how these files work)
Can you confirm that the highlighted joint reference is wrong
This is X Axis, joint 00
And this is Z Axis, joint 02. Should the highlighted say 2 rather than 0?
Edit. If the highlighted is wrong, looks like Mesa CT was correct for joint 00 but it has this error for joints 01 and 02, for PWM scale and Encoder scale.
Last edit: 13 Oct 2024 21:09 by flyingbrick.
Time to create page: 0.159 seconds
