Homing switches dont react, CNC goes on.
- TheProcessTechnician
21 Oct 2024 12:58 #312745
by TheProcessTechnician
Homing switches dont react, CNC goes on. was created by TheProcessTechnician
Hi there
Could solve the GPIO Problem, but now i got another problem:
The homing switches don't react.
Tested the switches and pins, everything does as it should (input is normally 1, if it touches it opens ->0), but if theĀ machine touches the switches, it goes on with driving. what did I do wrong?
INI file:
HAL file:
INI file:
HAL file:
- Thank you received: 2176
21 Oct 2024 14:27 - 21 Oct 2024 14:30 #312752
'joint.0.home-sw-in'
'joint.1.home-sw-in'
'joint.2.home-sw-in'
Change from 0 to 1 when the switch is activated?
Replied by Aciera on topic Homing switches dont react, CNC goes on.
Have you checked that the relevant pinseverything does as it should (input is normally 1, if it touches it opens ->0),
Last edit: 21 Oct 2024 14:30 by Aciera.
The following user(s) said Thank You: TheProcessTechnician
21 Oct 2024 14:44 #312754
Replied by TheProcessTechnician on topic Homing switches dont react, CNC goes on.
Value is set to FALSE even if I press the button.
21 Oct 2024 15:31 #312761
Follow the trail and watch the hal input pins:
net min-home-x <= hal_gpio.PIN40-in
net min-home-y <= hal_gpio.PIN36-in
net min-home-z <= hal_gpio.PIN38-in
If these are also not changing state (as I would expect) then you have a problem with the hal_gpio driver (which I know nothing about).
21 Oct 2024 18:08 #312781
Arrrrgs, im an idiot. forgot to add read to the base thread...
addf hal_gpio.read base-thread
Time to create page: 0.083 seconds
