- Configuring LinuxCNC
- Basic Configuration
- Mesa, Linuxcnc with step direction servo's for axis and analog servo spindle.
- mjones@welfab.ca
- Thank you received: 6
10 Nov 2024 19:54 #314204
by mjones@welfab.ca
Mesa, Linuxcnc with step direction servo's for axis and analog servo spindle. was created by mjones@welfab.ca
Hi Guys, I am having trouble getting my lathe to work.
It is an Old Superslant Hardinge. It has 4 axis, 2 turrets each with an x and z and each with 8 tool changer.
The problem I have is that I have a working hal that connects to the boards, and all the io's are working. But the drives both axis and spindle don't do anything. The axis I know the problem is that im wired for step and direction and the configurator doesn't give a setup for that, and using the step configurator and blending the file is giving me a major headache.as its difficult to see what parts of one I need and what parts I can't have.
I am running 7i76-7i77 and 7i64.
Any suggestions as to how I can make or blend a hal file that will do what I want would be appreciated.
- Thank you received: 7478
10 Nov 2024 20:22 #314210
Replied by tommylight on topic Mesa, Linuxcnc with step direction servo's for axis and analog servo spindle.
It would be much better to give us correct info about your setup, like what is attached to 7i76 and 7i77?
Or is it a 7i76E with 7i77?
Did you flash the correct firmware for whatever is in use?
What does readhmid return?
Do the boards have 5V and Field (12-24V) power?
- mjones@welfab.ca
10 Nov 2024 21:06 #314215
by mjones@welfab.ca
Replied by mjones@welfab.ca on topic Mesa, Linuxcnc with step direction servo's for axis and analog servo spindle.
7i76E is connected to the computer through ethernet, the 7i77 connects to the 7i76e with a ribbon cable and the 7i64 connects to the 7i77 with a modified ethernet cable.
The boards have 5v and 24v field power.
It has been a while since I wired and had time to do the cards but I remember that I did flash one for some reason or another. Does it need different flashing for step direction than for analog?
And sorry again, as I said it has been a while since I had time to get into this again and don't remember where to type readhmid
10 Nov 2024 21:37 #314216
No worries, we do need correct info to be able to give any help, 7i76 and 7i76E are the same thing but NOT the exact same thing.
Mesa can do step/dir and analog at the same time and so can LinuxCNC, so that is easy, just use mesaflash to check what firmware is already in the 7i76E, then we can decide if a flash is needed.
see in a terminal
man mesaflash
for how to use it.
see in a terminal
man mesaflash
for how to use it.
- mjones@welfab.ca
10 Nov 2024 21:59 #314217
by mjones@welfab.ca
Thanks for the quick response, I am always surprised at how quick you are.
Unfourtunatly I had to leave the shop and go home. In the morning I will see how well I can figure out how to get a man mesaflash to see what I have.
- mjones@welfab.ca
11 Nov 2024 13:49 #314240
by mjones@welfab.ca
Ok. I put man mesaflash in terminal and it came back with 'no manual entry for mesaflash.
I believe there is a sudo command to ask what the board information is, but I can't remember what it is.
- Thank you received: 5325
11 Nov 2024 14:12 #314242
Replied by PCW on topic Mesa, Linuxcnc with step direction servo's for axis and analog servo spindle.
try mesaflash --help
- mjones@welfab.ca
11 Nov 2024 14:43 #314246
by mjones@welfab.ca
I put in
mesaflash --device 7i76e --readhmid
it said 'no 7i76e board found
I just got called out on a service call, so have to go, unfortunately.
11 Nov 2024 14:51 #314248
You need to provide the cards IP address:
mesaflash --device 7i76e --addr 10.10.10.10 --readhmid
or
mesaflash --device 7i76e --addr 192.168.1.121 --readhmid
or
- mjones@welfab.ca
11 Nov 2024 15:07 #314252
by mjones@welfab.ca
Time to create page: 0.252 seconds
