etch servo configuration
- pdmore
23 Nov 2024 21:33 #315137
by pdmore
etch servo configuration was created by pdmore
Hello, my name is Daniel and I am from Argentina, can someone help me modify the configuration for etch servo via parallel port? I want to do some tests of its operation. Currently I have the HAL configuration in 1.1 mode but my h-bridge works pwm up, pwm down, I think I have to change to 2.2 mode but I don't know what else I have to modify.
Configuration attached.
Excuse my English, I use a translator.
Thank you
Greetings
Thank you
Greetings
- Thank you received: 5325
23 Nov 2024 22:58 - 23 Nov 2024 23:00 #315145
Replied by PCW on topic etch servo configuration
In addition to setting the PWM mode to up/down, you would need to change some names:
ORIGINAL
net Xpwm pwmgen.0.pwm
net Ypwm pwmgen.1.pwm
net Xdir <= pwmgen.0.dir
net Ydir <= pwmgen.1.dir
net Xdir => parport.0.pin-02-out
net Xdir => parport.0.pin-04-out
setp parport.0.pin-04-out-invert TRUE
net Xpwm => parport.0.pin-03-out
net Ydir => parport.0.pin-05-out
net Ydir => parport.0.pin-07-out
setp parport.0.pin-07-out-invert TRUE
net Ypwm => parport.0.pin-06-out
To something like:
net Xup pwmgen.0.up
net Yup pwmgen.1.up
net Xdown <= pwmgen.0.down
net Ydown <= pwmgen.1.down
net Xdown => parport.0.pin-02-out
net Xup => parport.0.pin-03-out
net Ydown => parport.0.pin-05-out
net Yup => parport.0.pin-06-out
Note that you may need to change the sign of the PWM scale or swap the up,down
parallel port pins to get the correct feedback direction.
ORIGINAL
To something like:
net Xup pwmgen.0.up
net Yup pwmgen.1.up
Last edit: 23 Nov 2024 23:00 by PCW.
- pdmore
24 Nov 2024 18:07 #315181
by pdmore
Replied by pdmore on topic etch servo configuration
Thank you very much, you are very kind, I have been trying to change the configuration for days without success, now it is perfect, we will see how it works in practice.
greetings
Daniel
greetings
Daniel
Time to create page: 0.171 seconds
