After homing move off of limit switch
1 year 10 months ago - 1 year 10 months ago #317263 by Dave2024
Well I’m not able to go into pncconf and have it load all the settings it only loads defaults.  I think it’s because when I switched PC’s all I did was copied the .ini and the .hal file into a quickly generated pncconf machine folder and never actually set it up on this PC.  I tried to set it up using your suggested procedure then copying the new lines and pasting them into my hal file but even with the new line:
# --- MAX-HOME-X ---
net max-home-x     <= [HMOT](CARD0).inm.00.input-02-not
 Its still homing correctly but then when jogging the table it goes to the max and engages the switch again but its not stopping and will proceed to crash.  I did however set MAX_LIMIT in the ini file and it wont crash but it would also be nice to have the limit switch also stop the table.
I think im going to give up for now.  Thanks for the help though.  Maybe ill try again in a few weeks when I find a serious reason to have to have the same limit switch stop the table.  What I have works for now
*Edit:  Wait never mind, I just found my origonal .xml setup file.  I see if i can get the files in the correct locations to load the pncconf data from the first time I set it all up on the first PC.  I let you know how it all goes.  Anyways thanks again for all the help*
Last edit: 1 year 10 months ago by Dave2024.
Time to create page: 0.159 seconds
