Probe basic Install errors
  • gblcody
  • gblcody's Avatar Topic Author
  • New Member
  • New Member
25 Dec 2024 05:50 #317326 by gblcody
Probe basic Install errors was created by gblcody
Hey guys, I'm struggling. I am beyond frustrated with trying to get Probe Basic to launch fully. I have been trying to get this to work for the better part of 18 hours.
Here is what I know.
I can launch the Dev with the sim on the PC.
I figured out that one of my issues was the screen size. I now have a compatible screen installed.
I have reinstalled the bookworm iso and followed the instructions several times.
I have cleaned and wiped the system at least 6 times and still always come back to an error launching.
i was having the issue of probe basic not launching error but after a wipe and reinstall and apt repair it seems to have gone away.
I am now stuck at this point where "I think" I'm missing the custom.hal. I can not find any hal file by that name.
I have attached a text file of the crash report. I would be very grateful for the help, as I just received a new touch probe that I would like to use.
I apologize in advance if this is in the wrong section.
Let me know if you need anything else! Keep on makin chips!
  • Moderator
  • Moderator
25 Dec 2024 08:19 #317329 by tommylight
Replied by tommylight on topic Probe basic Install errors
CANNOT FIND FILE FOR:custom.hal
Could not open command file 'shutdown.hal'
In your ini file you have references calling those two files, and those two files are not in your config folder.
If there is nothing you added to those files, edit the ini and omit those two entries calling those files, save, try again.
The following user(s) said Thank You: gblcody
  • gblcody
  • New Member
  • New Member
25 Dec 2024 15:39 #317355 by gblcody
Replied by gblcody on topic Probe basic Install errors
Tommylight,
Thanks for that tweak, I removed those hal calls in the ini file and that error is now gone. I'm now back to my issue of "Can't execute DISPLAY program probe_basic "
Any suggestions?
Attached are my error report and config files
Thanks again for the support and Merry Christmas!
