Tool setter setup
1 year 10 months ago #317461 by CaspianCmonster
Hi all, like many people out there I am trying to get a tool setter setup.
I am working from the example files but I think I have issues with file/folder mapping among other problems.
I get a startup error usr/share/axis/images/axis.ngc: pycall(remap.change_prolog) failed
I found a similar issue in my searches but haven't been able to figure it out.
many thanks
Luke
1 year 10 months ago #317464 by MaHa
Replied by MaHa on topic Tool setter setup
The path for python is missing in the ini
linuxcnc.org/docs/stable/html/remap/rema...emap:embedded-python
[PYTHON] # where to find the Python code: # code specific for this configuration PATH_PREPEND=./ # generic support code - make sure this actually points to Python-stdglue PATH_APPEND=../../nc_files/remap_lib/python-stdglue/ # import the following Python module TOPLEVEL=toplevel.py # the higher the more verbose tracing of the Python plugin LOG_LEVEL = 0
The following user(s) said Thank You: CaspianCmonster
1 year 10 months ago #317470 by CaspianCmonster
Replied by CaspianCmonster on topic Tool setter setup
thank you, that is clearly something I need to fix :)
It would be really nice if I could just start with the demo files and adjust them to my machine's specs but I haven't figured out how to get that to work.
Luke
1 year 10 months ago #317481 by CaspianCmonster
Hi, I am making progress I think.
the error I have now is that when I try test a file with an M6 command it I get an error
"Program exceeds machine maximum on axis Z"
It doesn't matter what code I have in there or where the machine is zeroed
I have found how to sets the locations of the probe but can't find the source for the probing travels (I think the gcode has a reference to the INI but I don't see anything there)
perhaps this is an inch vs mm thing,again I think that is correct in the file but it is a bit confusing.
thank you
Luke
1 year 10 months ago - 1 year 10 months ago #317485 by MaHa
Change position must be 0 or negative value
XYZ change positions are all in machinecordinates G53:
g53 g0 Z #<_ini[change_position]z>
Last edit: 1 year 10 months ago by MaHa.
1 year 10 months ago - 1 year 10 months ago #317492 by CaspianCmonster
Thanks, that was helpful. I am still not used to the coordinate system but the locations are now ok and it starts without errors but when I run M6 it goes to the tool change position but stops there with no prompts like there are in the demo.
I think manualtoolchange.glade isn't being used
thanks
Luke
Last edit: 1 year 10 months ago by CaspianCmonster. Reason: correction
Time to create page: 0.323 seconds
