Tool setter setup
1 year 10 months ago - 1 year 10 months ago #317502 by MaHa
Replied by MaHa on topic Tool setter setup
there must be a postgui.hal file, where the digital outputs M64 M65 and analog output M68 are connected, eg. motion.analog-out-00
Maybe from the source of your file, there are more infos.
In the ini file there is an entry for glade tab. Normally this tab should be loaded, when axis starts.  Maybe the tab gladevcp has some display or setting for toolchange
Last edit: 1 year 10 months ago by MaHa.
1 year 9 months ago #317817 by CaspianCmonster
Replied by CaspianCmonster on topic Tool setter setup
Happy New year everyone.
I am back in the workshop and have made some progress.
I did a new clean install with the current version and on a much more powerful computer as my original machine was just not happy being a super slow single board computer from 10 years ago. The only other computer I have around with a PCI slot is a massive dual Xeron workstation which is a great heater in the winter :)
I was chatting with some other folks about this and they suggested that using the qtdragon interface would perhaps be a good idea so I made a config with that and it is close to working but there are some errors around calling the python files. I  used the text from the manual and added the "examples" folder step so they should point correctly but I think there is something wrong, either with what I wrote or how the paths are written in the example. (I don't understand the format with the text over two lines with a ":/" but I am no linux expert.
Any ideas?
thanks
Luke
Time to create page: 0.109 seconds
