Simple Z touch off generating empty error [SOLVED]
- NotAllThere
07 Jan 2025 22:58 - 07 Jan 2025 23:26 #318358
by NotAllThere
Simple Z touch off generating empty error [SOLVED] was created by NotAllThere
I'm adding a touch probe to a ChinaZone 6040 with a Mesa 7i76e card following what seems to be pretty simple instructions from forum.linuxcnc.org/49-basic-configuratio...obe-with-a-mesa-7i96. It's really close, but generating an error.
When I click on "Tool Touch Off Z" in the side panel, I get a blank error (see attached pic):
<l> (?) [x]
Where should I look to find the problem? I've gone through the example a few times and am just missing it somehow. I've checked the Linux logs, but haven't found anything yet.
<l> (?) [x]
- Axis 2.8.4 (I can upgrade if that would help)
- Hal Meter signal probe-in turns to true when the touch probe is triggered, so the wiring & HAL seem correct
- I've run each of the commands in the ngc file using the MDI tab and they all function as expected
- The 5 updated files are attached and each has it's full path in the comments at the top of the file
Thanks,
Ted
Last edit: 07 Jan 2025 23:26 by NotAllThere.
- NotAllThere
07 Jan 2025 23:25 #318360
by NotAllThere
Replied by NotAllThere on topic Simple Z touch off generating empty error
D'oh! Figured it out. In case anyone else is as slow as I am...
In the ini file, my comm "MDI_COMMAND=0 <z_touch> CALL" was the 15th item in the HALUI list (starting with 0). So my custom_postgui.hal file should have been:
net ztouch halui.mdi-command-15 <= pyvcp.ztouch
All good now. Just need to measure offsets and we're running!
Time to create page: 0.578 seconds
