Rapid speeds
- vre
- Thank you received: 17
14 Jan 2025 22:05 #318983
by vre
Rapid speeds was created by vre
How can i find rapid speeds of machine ?
Is there an automated script that measures displacement/time to calculate rapid speed ?
Also how can measure max rpm of spindle with encoder installed ?
- Thank you received: 5325
14 Jan 2025 22:53 - 14 Jan 2025 23:00 #318986
Replied by PCW on topic Rapid speeds
In both cases, if the encoder is scaled correctly, the encoder velocity will read
machine units per second for linear axis and revolutions per second for spindles.
(there's also revolutions/distance per minute encoder velocity pin)
So if you can command a maximum speed (10V on an analog system)
you can measure the velocity/rpm with the encoder feedback.
For linear axis you will have disconnect the motor from the ballscrew to do this test
also the maximum actual speed will be 10-20% less than the speed at 10V
because the PID loop needs some overhead.
Last edit: 14 Jan 2025 23:00 by PCW.
- vre
16 Jan 2025 00:26 - 16 Jan 2025 00:26 #319066
by vre
Replied by vre on topic Rapid speeds
Where in the gui shows axis rapid linear speed?
I see only position in GUI DRO.
I want to measure this without uncoupling
motor from ballscrew.
I have set correct encoder scale also i know
that linear rapid speed is about 5000mm/min
but am not sure how much is exactly.
If i set man speed to 10000mm/min
this will enforce 7i33 to outout 10V.
So in this case how can i measure actual
linear speed without decoupling servomotor from ballscrew?
Last edit: 16 Jan 2025 00:26 by vre.
16 Jan 2025 00:42 #319068
This is all a bit dangerous if the servo motors are still connected to the linear
axis.
That said, if the joint and axis maximum velocities are increased slowly
there will be point where the following error increases rapidly (because
the actual position can no longer track the commanded position)
This is one way to determine the maximum speed (at 10V)
Watching the following error/velocity/PID output with halscope will help to find this point
axis.
- vre
16 Jan 2025 06:40 #319094
by vre
I want to find rapid speed if i give manually
10v to drives.
Where is this written to gui?
10v to drives.
16 Jan 2025 15:12 #319127
I would just watch the encoder velocity in halshow
The following user(s) said Thank You: vre
- vre
26 Feb 2025 05:16 - 26 Feb 2025 05:20 #322650
by vre
So to find rapid speed the trick is to set high initial rapid speed and watch ferror in halscope and at jog speed that ferror has huge increase minus for example 1% of that jog speed is the rapid speed?
Is there a way to force 7i33 to output 10V?
Also how can find max acceleration?
Last edit: 26 Feb 2025 05:20 by vre.
Time to create page: 0.344 seconds
