Rotating Axis Controlled by a Ballscrew
- Thank you received: 4654
17 Jan 2025 19:05 #319209
Replied by andypugh on topic Rotating Axis Controlled by a Ballscrew
I think that this is a perfectly valid approach, and as you have noted, it was used by Centroid.
The "right" way to do this is probably with a custom kinematics component. That way it is solved by mathematics.
linuxcnc.org/docs/stable/html/motion/kinematics.html
The following user(s) said Thank You: timo
- Gautham
- Thank you received: 3
20 Jan 2025 05:20 #319440
by Gautham
Replied by Gautham on topic Rotating Axis Controlled by a Ballscrew
Thank you Andy and thank you besriworld, I also feel this is a viable solution, Ofcourse what besriworld about the ballscrew taking radial load is true but we can fix that at a lower cost than some of the other solutions available. I will look into that aswell ass the solutions suggested by besriworld. Thank you all once again
Time to create page: 0.169 seconds
