Steppers Not Moving / Mapped Wrong
- notJamesLee
- Thank you received: 5
20 Jan 2025 20:10 #319485
by notJamesLee
Replied by notJamesLee on topic Steppers Not Moving / Mapped Wrong
okay further update.
I got the estop signals to show up on Halshow. for anyone in the future having a similar issue. I needed to connect the ground from the power supply to the TB3 pin 12 (int common). From there i went 24v+ --> NC on the switch --> Common the switch -- > to the mesa. I am using simple two lead limit switches.
My next questions is how to invert the pin in the hal so that the machine will power on and honest think the limit switches are always being pressed.
I am also considering putting one more on the tandem second y motor so i can square the axis every time i home the machine. Does is this a good idea? seems like free real estate.
thanks again.
thanks again.
- Thank you received: 5325
20 Jan 2025 20:59 #319486
Replied by PCW on topic Steppers Not Moving / Mapped Wrong
If you use pncconf to create your configuration, there a check box by the inputs
to invert them.
to invert them.
- Thank you received: 7478
20 Jan 2025 21:21 #319490
It MUST have 2 switches, one for each side, this can do gantry squaring every time the machine is homed.
Or if you want to use a single switch, do not set a tandem axis, just set two Y axis outputs/stepgens in the wizard, but this can not do squaring the gantry.
Replied by tommylight on topic Steppers Not Moving / Mapped Wrong
Wait, you can NOT set the machine with tandem axis with only one home switch on one side of the tandem axis.
- notJamesLee
21 Jan 2025 01:21 - 21 Jan 2025 01:27 #319509
by notJamesLee
I was able to figure it out in the hal. I just usedto invert all my inputs. My estop is even working too!
Okay this makes sense ill fire one and get it wired in. How would the hal differ below is my best attempt.
-not
# --- MIN-HOME-Y2 ---
net min-home-y2 <= hm2_7i96s.0.inm.00.input-04-not
Last edit: 21 Jan 2025 01:27 by notJamesLee. Reason: /code formatting
21 Jan 2025 02:30 #319517
Looks OK.
The following user(s) said Thank You: notJamesLee
Time to create page: 0.220 seconds
