7i73 input 0-7 i cant'use
- andreabonuc
07 Feb 2025 17:26 #320928
by andreabonuc
7i73 input 0-7 i cant'use was created by andreabonuc
Hi everyone, I have a 7i96s and a 7i73, until now I have used the 3 analog inputs of the 7i73 (in 0,1,2,3- pin 3,4,5,6) to use them with 3 potentiometers but they are not stable and I have not continued to use them. I would like to understand if they can be used as standard inputs because I have to move 4 external buttons to recover the 6 encoder inputs for the potentiometers. My problem is that I see them as inputs in halshow but I can't use them, I can use from in8 up. I certainly wrote something in the HAL to enable the analog inputs but I haven't solved anything for 2 days to get them working as standard inputs again. It's been more than 1 year since I changed the hal file and being a beginner I don't remember... Can anyone help me? Thanks.
- Thank you received: 5325
07 Feb 2025 18:23 - 07 Feb 2025 18:24 #320931
Replied by PCW on topic 7i73 input 0-7 i cant'use
Inputs 0..7 on the 7I73 have no pullups/pulldowns
so these must be added externally if used with
single throw switches.
Last edit: 07 Feb 2025 18:24 by PCW.
- andreabonuc
07 Feb 2025 18:56 #320934
by andreabonuc
Replied by andreabonuc on topic 7i73 input 0-7 i cant'use
sorry but I'm not very expert, what do you mean by added externally? Can you explain it to me practically? Thank you
07 Feb 2025 21:25 - 07 Feb 2025 21:25 #320941
You would need to add an external resistor from 3.3V to each input (0 through 7)
connected to a switch, assuming the switch switches to ground (a 4.7K resistor is a reasonable value)
If the switch/button has NO and NC contacts you can do without the resistor, but a normal
SPST switch needs the resistors.
Last edit: 07 Feb 2025 21:25 by PCW.
The following user(s) said Thank You: andreabonuc
- andreabonuc
07 Feb 2025 22:04 #320942
by andreabonuc
I use a momentary switch and will insert a 4.7 k ohm resistor. Thanks for your help!
Time to create page: 0.163 seconds
