Feedrate doesn't go above 1500 when running jobs.
- baikal718
11 Feb 2025 22:53 #321289
by baikal718
Feedrate doesn't go above 1500 when running jobs. was created by baikal718
Hey, guys.
I've been trying to get my feedrate above 1500 and can't seem to accomplish that. I've gone through the accel and velocity tests in pcncconf and found the numbers that work with my machine. I can jog at high feedrates, but any jobs or mdi commands cap me at a lovely 1500 feedrate. Can somebody look over my ini and tell me what line I've missed? Is it a Qtdragon setting?
Thanks in advance
Thanks in advance
- Thank you received: 7478
11 Feb 2025 23:04 #321292
Replied by tommylight on topic Feedrate doesn't go above 1500 when running jobs.
There is also the [TRAJ] section with speed limits
MAX_LINEAR_VELOCITY = 25.00
so raise that to probably 100 as in the display section.
- baikal718
11 Feb 2025 23:16 #321293
by baikal718
Replied by baikal718 on topic Feedrate doesn't go above 1500 when running jobs.
Yup, already tried raising that one as well, unfortunately it didn't help.
11 Feb 2025 23:50 #321298
Are you sure you are editing the correct file?
Check and recheck, as that is the only thing.
The following user(s) said Thank You: baikal718
- baikal718
12 Feb 2025 00:10 #321300
by baikal718
Turns out Kate was not saving my file changes for some reason. Thank you for your quick help, all is working now.
Time to create page: 0.153 seconds
