Not all ports of my MESA boards are visible
1 year 8 months ago #322358 by EGR
Dear Forum
Time to restart working on my cnc, but I'm facing problems, all my apologies in advance if answers are obvious but I missed them anyway
- Fresh clean install of LinuxCNC (2.9.4) with udpates/upgrades done
- a 6I24 connected to a 7I53 (adhoc bitfile)
- a 6I25 connected to a 7I76 and to a 7I74, itself connected to a 7I70 & 7i71 & 7I73
- both 6I's have PC power disabled and 7i53, 7i76 & 7i74 are powered with 5V
-7i76, 7i70 &  7i71 are also powered with 24V (common com), 7I73 not yet ready
Now with preliminary pncconf config to run linuxcnc, when I run readhmid on the 6i25 it seems that I'm missing some ports and I cannot connect them through pncconf: What am I missing ?
Thanks a lot
Emeric
sudo mesaflash --device 5i25 --readhmid :
Configuration Name: HOSTMOT2
  BoardName : MESA5I25
  FPGA Size: 9 KGates
  FPGA Pins: 144
  Number of IO Ports: 2
  Width of one I/O port: 17
  Clock Low frequency: 33.3333 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  ClockFrequency: 33.333 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: IOPort
  There are 2 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: QCount
  There are 1 of QCount in configuration
  Version: 2
  Registers: 5
  BaseAddress: 3000
  Module: SSerial
  There are 2 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  Instance Stride: 64 bytes
  Module: StepGen
  There are 5 of StepGen in configuration
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
DB25 pin#             I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir
 1                      0   IOPort       StepGen          0        Dir/Table2      (Out)
14                      1   IOPort       StepGen          0        Step/Table1     (Out)
 2                      2   IOPort       StepGen          1        Dir/Table2      (Out)
15                      3   IOPort       StepGen          1        Step/Table1     (Out)
 3                      4   IOPort       StepGen          2        Dir/Table2      (Out)
16                      5   IOPort       StepGen          2        Step/Table1     (Out)
 4                      6   IOPort       StepGen          3        Dir/Table2      (Out)
17                      7   IOPort       StepGen          3        Step/Table1     (Out)
 5                      8   IOPort       StepGen          4        Dir/Table2      (Out)
 6                      9   IOPort       StepGen          4        Step/Table1     (Out)
 7                     10   IOPort       SSerial          0        TXData0         (Out)
 8                     11   IOPort       SSerial          0        RXData0         (In)
 9                     12   IOPort       SSerial          0        TXData1         (Out)
10                     13   IOPort       SSerial          0        RXData1         (In)
11                     14   IOPort       QCount           0        Quad-IDX        (In)
12                     15   IOPort       QCount           0        Quad-B          (In)
13                     16   IOPort       QCount           0        Quad-A          (In)
IO Connections for P2
 1                     17   IOPort       SSerial          1        RXData0         (In)
14                     18   IOPort       SSerial          1        RXData1         (In)
 2                     19   IOPort       SSerial          1        RXData2         (In)
15                     20   IOPort       SSerial          1        RXData3         (In)
 3                     21   IOPort       SSerial          1        TXData0         (Out)
16                     22   IOPort       SSerial          1        TXData1         (Out)
 4                     23   IOPort       SSerial          1        TXData2         (Out)
17                     24   IOPort       SSerial          1        TXData3         (Out)
 5                     25   IOPort       SSerial          1        RXData4         (In)
 6                     26   IOPort       SSerial          1        RXData5         (In)
 7                     27   IOPort       SSerial          1        RXData6         (In)
 8                     28   IOPort       SSerial          1        RXData7         (In)
 9                     29   IOPort       SSerial          1        TXData4         (Out)
10                     30   IOPort       SSerial          1        TXData5         (Out)
11                     31   IOPort       SSerial          1        TXData6         (Out)
12                     32   IOPort       SSerial          1        TXData7         (Out)
13                     33   IOPort       SSerial          1        TXEn7           (Out)
1 year 8 months ago #322366 by PCW
My first guess is that the sserial channels on the 7I74 are not enabled in the hal file
(with a sserial_port_1=00000000 stanza in the hm2_pci driver loadrt line)
1 year 8 months ago #322942 by EGR
Thanks a lot, I will try asap.
Have a great day
Emeric
Time to create page: 0.058 seconds
