Good afternoon
Everyone
First of all, I would like to thank you for all the help I received in this forum, especially from Mr. PCW. With this help, I was able to go far and achieve a satisfactory result.
However, although the machine is working, the customer wants more speed on the Z axis. I don't know if I'm already at the mechanical limit of this machine, but what parameters can I change and how can I change and calculate them to test the limit of this machine? If anyone can give me a tip on how to change the INI file to improve performance, I would be very grateful.
Below is the video of the machine that was retrofitted and working perfectly with the boards from the manufacturer Mesa.
Below is the INI code
[code]# Generated by PNCconf at Sat Apr 27 14:56:11 2024
# Using LinuxCNC version: 2.8
# overwritten when you run PNCconf again
[EMC]
MACHINE = 7i96s+7i84d
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = gmoccapy
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/linoteck/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
DEFAULT_LINEAR_VELOCITY = 6.000000
MAX_LINEAR_VELOCITY = 25.000000
MIN_LINEAR_VELOCITY = 0.500000
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyzab
#ABATELA
EMBED_TAB_NAME=Alarmes
EMBED_TAB_COMMAND = gladevcp -x {XID} -H ui-alarmes.hal alarmes.ui
EMBED_TAB_LOCATION = ntb_user_tabs
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
RS274NGC_STARTUP_CODE = G21 G40 G90 G94 G97 G64 P0.025
REMAP= M6 modalgroup=6 ngc=sub_progs/troca_ferramenta
USER_M_PATH = /home/linoteck/linuxcnc/nc_files/m_codigos/
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 1000000
[HMOT]
# **** This is for info only ****
CARD0=hm2_7i96s.0
[HAL]
HALUI = halui
HALFILE = 7i96s+7i84d.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
HALFILE = classicladder.hal
[HALUI]
[HALUI]
# add halui MDI commands here (max 64)
[KINS]
JOINTS = 5
KINEMATICS = trivkins coordinates=XYZAB
[TRAJ]
COORDINATES = XYZAB
MAX_ANGULAR_VELOCITY = 360.00
DEFAULT_ANGULAR_VELOCITY = 36.00
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 16.00
MAX_LINEAR_VELOCITY = 160.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_X]
MAX_VELOCITY = 160.0
MAX_ACCELERATION = 10000.0
MIN_LIMIT = -0.01
MAX_LIMIT = 1250.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
STEPGEN_MAXVEL = 200
STEPGEN_MAXACCEL = 12500
P = 1000
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 0
# these are in nanoseconds
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 10000
STEPSPACE = 10000
STEP_SCALE = 250
MIN_LIMIT = -0.01
MAX_LIMIT = 1250.0
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = -33.316667
HOME_LATCH_VEL = -33.316667
HOME_FINAL_VEL = 0.000000
#HOME_USE_INDEX = NO
#HOME_SEQUENCE = 1
[AXIS_Y]
MIN_LIMIT = -0.01
#MAX_LIMIT = 1293.0
MAX_LIMIT = 1164.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
P = 1000
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 0
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 9000
STEPSPACE = 10000
STEP_SCALE = 250
MIN_LIMIT = -0.01
MAX_LIMIT = 1293.0
#HOME_SEQUENCE = 1
[AXIS_Z]
#MAX_VELOCITY = 25.0
MAX_VELOCITY = 50.0
#MAX_ACCELERATION = 750.0
MAX_ACCELERATION = 1000.0
#MIN_LIMIT = -100.0
#MAX_LIMIT = 0.01
MIN_LIMIT = -100.0
MAX_LIMIT = 100.0
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 50
MIN_FERROR = 50
MAX_VELOCITY = 125.0
MAX_ACCELERATION = 1750.0
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
ENCODER_SCALE = 415
OUTPUT_SCALE = 10
OUTPUT_MIN_LIMIT = -10.0
OUTPUT_MAX_LIMIT = 10.0
MIN_LIMIT = -100.0
MAX_LIMIT = 100.0
HOME_OFFSET = 0.0
#HOME_SEQUENCE = 0
[AXIS_A]
MAX_VELOCITY = 360.0
MAX_ACCELERATION = 1200.0
MIN_LIMIT = -500.0
MAX_LIMIT = 500.0
[JOINT_3]
#TYPE = ANGULAR
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
STEPGEN_MAXVEL = 450
STEPGEN_MAXACCEL = 1500
P = 1000
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 0
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = 222
MIN_LIMIT = -500.0
MAX_LIMIT = 500.0
HOME_OFFSET = 0.0
#HOME_SEQUENCE = 1
[AXIS_B]
MIN_LIMIT = -45000.0
MAX_LIMIT = 45000.0
[JOINT_4]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
P = 1000
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 0
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 10000
STEPSPACE = 10000
STEP_SCALE = 142
MAX_LIMIT = 45000.0
HOME_OFFSET = -92.000000
#HOME_SEQUENCE = 1
[SPINDLE_0]
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 2000
[/code]
