now i have no idea what is going on.
with the 5i25_7i76x2_2pd loaded my hal does load the pwm without alarm (i have not checked actual output though) but my A(3) axis does not work. If i revert to 5i25_7i76x2 A axis is good but obviously no pwm
thanks
Not likely, you need hardware PWM for that.another question
i know the standard io pins can not pwm very fast.
i only need 10K freq can they acheive that?
