Spindle control not showing in Axis window...
1 year 6 months ago #325640 by irwinger
Coming back to my CNC wood router after a good year off (controller PC hard drive died and I got busy renovating my house). I have a new hard drive, doubled the memory (16G), fresh and latest install downloaded last week from here (linuxcnc.org) and I have everything back 'moving and stopping'... except the spindle.
I have an old TB6560 3-axis, chinese controller board (Wantai) driven from my parallel port. It has the outputs for the 3 axes (yes - that is plural for axis - I looked it up) and a spindle on/off control output that I use to control a relay that switches the 120VAC to the Dewalt router.
Back in the 'old days' (when this system worked), there was a section just below the jog/home/tool touchoff buttons where I could turn the spindle on and off. It's not there any more. I've been trying to use Google Gemini and ChatGPT for help (and they are surprisingly helpful if the question is worded well), but I'm just not getting it to work.
I'm using steppers and configured my pins using StepConf. I set the pin for the spindle as parallel port pin 9. But I'm not seeing a [SPINDLE] section in the .ini file nor am I seeing any spindle references in the .HAL file. I can't control the spindle speed (it's a router), only whether it's on or off.
Anyone out there with a good idea of where to start?
Arden
1 year 6 months ago #325649 by tommylight
Upload the hal and ini files here so we can have a look.
In the meantime a stab in the dark would be to change LOCALE to UTF.8 and try making a new config, you can have multiple configs for the same machine.
1 year 6 months ago #325650 by irwinger
I'm not in front of the LinuxCNC machine as I enter this - but I'm not sure I noticed any where I can change the LOCALE? Could you perhaps provide a bit more detail? I'm heading out to the shop right after I press 'Submit' to see if I can find something. Meanwhile - here are the INI and HAL files.
INI:
There was no [SPINDLE] section when I finished with the StepConf. I added the entire '[SPINDLE]' section from a response from Google Gemini.
# Generated by stepconf 1.1 at Thu Apr  3 15:12:55 2025
# overwritten when you run stepconf again
[EMC]
MACHINE = X90
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 10mm 20mm 50mm 100mm 1in 2in 5in 10in
MAX_FEED_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.5
MAX_SPINDLE_OVERRIDE = 1.2
DEFAULT_LINEAR_VELOCITY = 0.10
MIN_LINEAR_VELOCITY = 0
MAX_LINEAR_VELOCITY = 1.00
CYCLE_TIME = 0.100
INTRO_TIME = 5
PROGRAM_PREFIX = /home/awalde/linuxcnc/nc_files
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
[KINS]
JOINTS = 3
KINEMATICS = trivkins coordinates=XYZ
[FILTER]
PROGRAM_EXTENSION = .nc,.tap G-Code File
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
BASE_PERIOD = 100000
SERVO_PERIOD = 1000000
[HAL]
HALFILE = X90.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[SPINDLE]
P=1.0
I=0.0
D=0.0
ENCODER_SCALE=0.0
MAX_RPM=1
MIN_RPM=0
ORIENT_PIN=
ORIENT_SPEED=0
[TRAJ]
COORDINATES =  X Y Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
#*** AXIS_X *******************************
[AXIS_X]
MAX_VELOCITY = 1.0
MAX_ACCELERATION = 30.0
MIN_LIMIT = -0.01
MAX_LIMIT = 8.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.01
MAX_LIMIT = 8.0
MAX_VELOCITY = 1.0
STEPGEN_MAXACCEL = 37.5
SCALE = 8000.0
FERROR = 0.05
MIN_FERROR = 0.01
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = 0.050000
HOME_LATCH_VEL = 0.050000
HOME_IGNORE_LIMITS = YES
#*** AXIS_Y *******************************
[AXIS_Y]
MAX_VELOCITY = 1.0
MIN_LIMIT = -0.01
MAX_LIMIT = 8.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.01
MAX_LIMIT = 8.0
MAX_VELOCITY = 1.0
SCALE = 8000.0
FERROR = 0.05
MIN_FERROR = 0.01
#*** AXIS_Z *******************************
[AXIS_Z]
MAX_VELOCITY = 1.0
MIN_LIMIT = -4.0
MAX_LIMIT = 0.01
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -4.0
MAX_LIMIT = 0.01
MAX_VELOCITY = 1.0
SCALE = 8000.0
FERROR = 0.05
MIN_FERROR = 0.01
HOME_OFFSET = 0.0
HAL: (initially generated from StepConf - but significantly edited as I tested the hardware)
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
loadrt hal_parport cfg="0 out"
setp parport.0.reset-time 5000
loadrt stepgen step_type=0,0,0
addf stepgen.update-freq servo-thread
net xstep           => parport.0.pin-01-out
setp parport.0.pin-01-out-reset 1
net yenable         => parport.0.pin-02-out
setp parport.0.pin-03-out-invert 1
net zdir            => parport.0.pin-03-out
net ydir            => parport.0.pin-04-out
net ystep           => parport.0.pin-05-out
setp parport.0.pin-05-out-reset 1
net zenable         => parport.0.pin-06-out
net xdir            => parport.0.pin-07-out
net zstep           => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
net spindle-on      => parport.0.pin-09-out
net estop-ext       <= parport.0.pin-10-in
net min-home-z      <= parport.0.pin-11-in
net min-home-y      <= parport.0.pin-12-in
net min-home-x      <= parport.0.pin-13-in
net xenable         => parport.0.pin-14-out
setp stepgen.0.position-scale [JOINT_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 70000
setp stepgen.0.dirsetup 70000
setp stepgen.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net xpos-cmd joint.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => joint.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable joint.0.amp-enable-out => stepgen.0.enable
net min-home-x => joint.0.home-sw-in
net min-home-x => joint.0.neg-lim-sw-in
setp stepgen.1.position-scale [JOINT_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 70000
setp stepgen.1.dirsetup 70000
setp stepgen.1.maxaccel [JOINT_1]STEPGEN_MAXACCEL
net ypos-cmd joint.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => joint.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable joint.1.amp-enable-out => stepgen.1.enable
net min-home-y => joint.1.home-sw-in
net min-home-y => joint.1.neg-lim-sw-in
setp stepgen.2.position-scale [JOINT_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 70000
setp stepgen.2.dirsetup 70000
setp stepgen.2.maxaccel [JOINT_2]STEPGEN_MAXACCEL
net zpos-cmd joint.2.motor-pos-cmd => stepgen.2.position-cmd
net zpos-fb stepgen.2.position-fb => joint.2.motor-pos-fb
net zstep <= stepgen.2.step
net zdir <= stepgen.2.dir
net zenable joint.2.amp-enable-out => stepgen.2.enable
net estop-ext => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
1 year 6 months ago #325658 by tommylight
No spindle there at all.
Make a new config, choose a spinlde, choose some rough values for spindle PWM, save, start the config see if it shows the spindle.
1 year 6 months ago #325712 by andypugh
The Axis interface hides the spindle buttons if it doesn't see certain connections in the HAL file:
github.com/LinuxCNC/linuxcnc/blob/master...cripts/axis.py#L4201
1 year 6 months ago - 1 year 6 months ago #325720 by irwinger
You'll have to forgive me guys but...
@tommylight - your statement is confusing... I assume you are meaning the .HAL file, because I specifically added the '[SPINDLE]' section to the .INI file. I won't claim it was correct or useful... it was what Google Gemini suggested when I asked (don't shoot me - I've had good success with the AI bots and frankly, I'm just TOO old to try to master 'everything technical'.
Taking your suggestion - I created a new config by starting LinuxCNC, selecting: (attaching screenshots of what I encountered in sequence)
Last edit: 1 year 6 months ago by irwinger. Reason: Remove inline images
Time to create page: 0.058 seconds
