I've got a new install on an RPi4 with a 7i92TF and an MX3660. The DB25 is on a ribbon cable with a third cable end pressed onto it. I have A step/dir on pins 8/9. The MX3660 does also use 8/9 but only to drive isolated outputs that aren't connected to anything.
IIRC I used the Geckodrive G540 flash on the 7i92. The readhmid is enclosed. DB25 8/9 should be stepgen 03.
I don't have homing set up yet. XY jog fine.
Initially, I saw XYZ axes moved ok but then I tried to jog A and both A and Z moved. That's as best I recall, it was late last night.
I looked at what I had in the hal and, ok, the joint and stepgens for A were off like that. IIRC what I saw had A on stepgen 2.
I did the logical thing and X=Joint 0 stepgen 0, Y=Joint 1 stepgen 1, Z=Joint 2 stepgen 2, A= Joint 3 stepgen 3. Order XYZA. HAL/ini enclosed.
At least that's what I tried to do. The machine thinks differently, I keep looking for the prob in the hal/ini but I don't see where the typo is.
The problem is, any attempt to jog to Z (keyboard, MDI) won't physically move anything, although the Z in AXIS does increment.
But, if I select the radio button for A axis, or use the MDI on A axis, it moves both the A and Z.
I unplugged the A-axis DB25 tap. Z commands won't move the Z, A commands do still move the Z, but of course A is disconnected so it won't move.
What am I missing here?
