None of the axis are moving - using mesa 7i92t with 7i76u
- SteepLearningCurve
01 May 2025 21:12 #327467
by SteepLearningCurve
None of the axis are moving - using mesa 7i92t with 7i76u was created by SteepLearningCurve
Hi All
Please can someone suggest next steps to try to get this to work.
I am a novice at this, so it must be something obvious, it’s just not obvious to me
Please see hal, ini, io attached.
I have a gantry X Y Y Z (two y motors)
I am using a Mesa 7i92TM connected from P1 to a Mesa 7i76U.
I have tried latest linuxcnc images on both Raspberry pi4 and on Intel NUC, and get the same outcome.
I used current version of mesact
The Linuxcnc dro counts on the screen, but the actual motors don’t move.
It looks like It counts in all axis until the software limits are reached, then errors.
When switched off, you can move gantry by hand in any direction.
When switched on, the gantry is rigid.
Stepper drivers are all DM556T.
Green led shows on all four of the stepper drivers (no red led on any of them)
I have wired from 7i76u to stepper drivers in differential mode, and in single ended mode with common ground, it made no difference, no axis moved.
The watchdog led in middle of Mesa 7i76U is green, and flashes approximately every second.
I have four inputs. Limit switches on the x and z axis, and proximity sensors on both ends of y axis.
In halshow, all four inputs are yellow, and go red if you trigger any of them.
Please can you suggest where to look next, or what config changes to try.
Many thanks
Many thanks
- Thank you received: 5326
01 May 2025 21:55 #327469
Replied by PCW on topic None of the axis are moving - using mesa 7i92t with 7i76u
I would first try setting the step time and step space to 5000 (5 usec)
since 2500 (2.5 usec) is the drives minimum (0 margin)
Also check the 5V at the 7I76U to make sure its not low
01 May 2025 22:27 #327472
Replied by SteepLearningCurve on topic None of the axis are moving - using mesa 7i92t with 7i76u
Hi PCW
Thanks for your prompt reply
I changed the step time and space time to 5000 for all four motors, switched off everything, and restarted , however it makes no difference (the motors don't move)
I was not sure where to measure the 5v, but choose 7i76u's TB2 connector and checked axis 0 through 3 , using the ground and +5VP on each axis, and all measure 4.9v . (The 5v comes from the 7i92T).
- Thank you received: 7478
01 May 2025 23:08 #327473
Replied by tommylight on topic None of the axis are moving - using mesa 7i92t with 7i76u
Attach a picture of the wiring here so we can have a look.
01 May 2025 23:14 - 01 May 2025 23:17 #327474
Also you might try checking that the direction pins change state when jogging in either direction
(you will have to disable homing to do this test)
Last edit: 01 May 2025 23:17 by PCW.
01 May 2025 23:36 #327475
In that case, the configuration file is incorrect. P1 is for the second 7I76
(which has stepgens 5 .. 9)
It's expected if you have a single 7I76, that it be connected to P2
02 May 2025 00:23 #327478
7i92TM should be possible to directly plug into 7i76U without cable.
03 May 2025 17:21 #327611
Hi All
I have tried a few variations of wiring (but plugging it in to P1 surely didn’t help), more about that shortly.
I tried this
Mesa 7i76u TB2 axis to DM556T signal in.
Differential wiring:
GND
STEP- to PUL-
STEP+ to PUL+
DIR- to DIR-
DIR+ to DIR+
+5VP
(with ENA+ and ENA- on DM556T not connected)
I tried the same as above with
GND wired to ENA-
then
+5VP wired to ENA+
then
with both wired.
See Control Signals image which shows two different wiring for single ended.
I don’t know which type the Mesa 7i76u control uses, but I tried both of these.
Open-collector signal ties +5VP to PUL+ , DIR+ and ENA+
PUL- to PUL-
DIR- to DIR-
PNP signal ties GND to PUL-, DIR- and ENA-
STEP+ to PUL+
DIR+ to DIR+
Enable_disable image mentions this …
Enable signal:
This signal is used for enabling/disabling the drive.
High level +5V (NPN control signal) for enabling the drive, and low level for disabling the drive.
PNP and Differential control signals are on the contrary, namely Low level for enabling.
By default it is left UNCONNECTED (ENABLED).
I tried this
GND
STEP- to PUL-
STEP+ to PUL+
DIR- to DIR-
DIR+ to DIR+
+5VP
GND wired to ENA-
then
+5VP wired to ENA+
then
with both wired.
PUL- to PUL-
DIR- to DIR-
STEP+ to PUL+
DIR+ to DIR+
Enable signal:
03 May 2025 17:57 #327615
Do not wire Enable until you get things working.
03 May 2025 18:25 #327623
Yep, on simple step drives, its a DISABLE input.Do not wire Enable until you get things working.
