+ and - both go same direction
04 May 2025 02:48 - 04 May 2025 02:49 #327651 by clayton2ndtry
+ and - both go same direction was created by clayton2ndtry
I have used 2.7.14 for several years now without problems.  Friday, Chromium stopped working so I reinstalled it.  Now _ and - both go the same direction.  So I reinstalled. No change.  Suggestions?  Sherline mill.
Last edit: 04 May 2025 02:49 by clayton2ndtry.
  • Moderator
  • Moderator
04 May 2025 03:07 #327652 by tommylight
Replied by tommylight on topic + and - both go same direction
Chromium has nothing to do with no direction change.
Check wiring first, most probably loose wire inside a connector or broken wire.
04 May 2025 03:20 #327654 by clayton2ndtry
Replied by clayton2ndtry on topic + and - both go same direction
I saw discussion of dirty parallel port PCI connection, so I started looking. The parallel port to controller box has a USB cord supplying power. I had taken the tower in the house where I had Ethernet because 2.7.14 has no built-in WiFi driver. I neglected to plug that cable into a USB port when I took it back to the shop. Everything works again! Thanks!
  • Moderator
  • Moderator
04 May 2025 13:16 #327677 by tommylight
You are welcomed, always.
Time to create page: 0.483 seconds
