New Config, issues with homing.
10 May 2025 23:00 #328182 by ccatlett1984
New Config, issues with homing. was created by ccatlett1984
Link to my current config: github.com/ccatlett1984/LinuxCNC_configs/tree/main/dmc_test
I have attached a image of the machine, with limit switch locations and homing direction labelled.
I'm not getting past Z homing, it travels up (the correct direction), I can see the limit switch activate in hal show config, but it doesn't stop and mark the axis homed.
These are the limit switches: (I believe the not's are correct, as those switches are NC)
net min-home-x          <=  hm2_7c80.0.inmux.00.input-15-not
net min-home-y          <=  hm2_7c80.0.inmux.00.input-14-not
net max-home-z          <=  hm2_7c80.0.inmux.00.input-13
10 May 2025 23:18 #328183 by PCW
Replied by PCW on topic New Config, issues with homing.
Is the Z axis switch Normally Open?
( a reversed axis and inverted home switch might behave like this as it would
back-off the activated switch instead of the search move )
10 May 2025 23:28 #328184 by ccatlett1984
Replied by ccatlett1984 on topic New Config, issues with homing.
Coorrect Z is a NO switch, X and Y are NC
10 May 2025 23:46 #328185 by PCW
Did you verify that
joint.2.home-sw-in
Goes true when the Z axis limit switch is triggered?
11 May 2025 04:01 #328186 by rodw
Replied by rodw on topic New Config, issues with homing.
I think your latch velocity is going the wrong way. You need it to back off the home switch so it can't have the same sign.
in your ini try
HOME_LATCH_VEL = -0.500000
11 May 2025 13:35 #328199 by PCW
Changing the latch velocity is worth a try _but_ having the same sign on search velocity as latch velocity is valid.
In this case, The homing logic is supposed to move towards the home switch at the search velocity, and when the
home switch is detected, reverse and back off until the home switch deactivates, and then move towards the home
switch again at the latch velocity for the final home switch detection.
11 May 2025 19:05 - 11 May 2025 19:06 #328211 by rodw
I did check one of my known good configs with a shared home/limit before my last reply. It uses a negative latch velocity.
github.com/rodw-au/vmnmillqt/blob/main/VMNmillQT.ini#L247
(units are metric)
Latching happens so quickly its hard to see what is going on. Sometimes I've slowed homing velocities right down (to 10% or less) to troubleshoot.
Last edit: 11 May 2025 19:06 by rodw.
  • Moderator
  • Moderator
11 May 2025 19:49 #328219 by tommylight
Replied by tommylight on topic New Config, issues with homing.
Just checked some 15 of my old and new configs, luckily i found one where search is positive and latch is negative (on Z), all others are same direction.
11 May 2025 19:56 #328222 by rodw
I checked another config of mine and it was positive.
github.com/rodw-au/showstopper/blob/master/my_Plasma.ini#L260
I wonder if the sign matters? I don't have the machine anymore to check.
11 May 2025 20:10 #328226 by rodw
Actually, the sign does matter because I have had machines where one side of the gantry does not home until the sign is flipped!
Time to create page: 0.378 seconds
