New Config, issues with homing.
- Thank you received: 7478
11 May 2025 20:32 #328227
Replied by tommylight on topic New Config, issues with homing.
Maybe i was not detailed enough, all configs have search and latch velocity positive for both, OR negative for both, plenty of those configs, only one has one joint where those two values are not the same direction.
To be more helpful, use Rod's advice and slow down everything to a crawl so you can actually see what is going on.
Before that, do absolutely make sure the motor direction is correct.
- ccatlett1984
- Thank you received: 3
11 May 2025 20:35 #328229
by ccatlett1984
Replied by ccatlett1984 on topic New Config, issues with homing.
Welp, homing switches were 100% inverted.
Homing now works on Z and Y, I have a wiring/driver/stepper issue to diagnose on X.
Time to create page: 0.105 seconds
