Need guidence to improve latency and speed
  • npostma
  • npostma's Avatar Topic Author
  • Junior Member
  • Junior Member
16 May 2025 18:02 #328588 by npostma
Replied by npostma on topic Need guidence to improve latency and speed
Thanks. I've put in the order for this card. Expected the 22th of may :-)
16 May 2025 18:12 - 16 May 2025 18:30 #328589 by PCW
From what I’ve researched, the Mesa 7i76EU seems like the best option. Here’s why:
It has 32 opto-isolated inputs which should work well with the 24V NPN homing sensors
The 7I76EU inputs work directly with PNP sensors (or switches) NPN sensors will require pull-up resistors.
The sensors might need a pull-down resistor to give clean logic signals when connected to 24V. I already solderd a pc to convert the 30V signal back to a 5V system with opto's
7I76EU isolated inputs do not require any additional components with PNP sensors or switches.
Note that 5V signals will not work when you have 24V field power as the input threshold will be about
12V in this case.
Last edit: 16 May 2025 18:30 by PCW.
The following user(s) said Thank You: npostma
Time to create page: 0.254 seconds
