The numpty needs help
21 May 2025 01:02 #328839 by jonsar
The numpty needs help was created by jonsar
Hi All
i am starting to pull what little hair i have left out and i need some help
il start from the beginning , I have a hobby cnc it runs Ubuntu 10.04 and it runs ok but it is a pox 14 years old
I would like to update to Debian 12  . I have set up a hard drive with this and have Been setting up the stepconf files.
i know there has been a lot of changes in 14years , I am struggling with the pin conf .i have the old files and have been working them across to the new but the estop is causing me grief is there any body that knows how the 2 systems are different . I dont mean in a big sense what i mean is in he stepconf system so i can see where i am going long thanks
21 May 2025 07:35 #328848 by tommylight
Replied by tommylight on topic The numpty needs help
Personally, i would not update if everything is working properly, i still have plenty of machines running 10.04.
The main reason being, 10.04 uses RTAI kernel, while everything after Wheezy uses RT-Preempt kernel that is better suited to new PC's, so it might limit the step rate you can get/machine speed, sometimes a lot.
If you still want to move ahead, upload the old and the new configs here.
Usually the wizard will convert working configs form 2.5-2.7 to 2.8-2.9 without issues the first time you run the old config, so what happened? Does the machine have non standard ...something or anything?
Right click on the old .ini file, choose open with, type linuxcnc near the bottom of that window, click OK, what happens?
Time to create page: 0.097 seconds
