problems with Verser Probe Screen 2.9
24 May 2025 12:59 #329042 by theoneandonlyoreo
problems with Verser Probe Screen 2.9 was created by theoneandonlyoreo
I'm trying to install probing on LinuxCNC 2.9 using the Axis GUI.  The tab appears, with icons, when I run linuxcnc.  When I click any buttons, I get errors that certain pins are not defined (ps_probe and such).  These pins, I gather, are dynamically created by probe_screen.py.
I'm not sure where in the sequence it is executed but it appears in the [DISPLAY] section in the EMBED_TAB_COMMAND variable (with -u) and the postgui.hal file.  In that HAL file, the current problem is that "loadusr -W psng/python/probe_screen.pl" causes linuxcnc to shutdown before the main GUI screen appears.  The debug info says that probe_screen.py did not return.  If I remove -W, the GUI launches and everything is fine until I try to interact with the items on the PSNG tab.
There are so many oddities in this install.  For example, in probe_screen.py there are many calls to _("some string") which is an adaptation for other languages.  Why it is used when gettext is not imported, I have no idea.  I made a pass-through function that returns the string:  def _(message):  return message. I feel uneasy about making changes like this.
I'm an experienced linux user, programmer, and electrical engineer but this is kicking my ass.  Has anyone else had problems like this?  Should I be starting with a different version or fork?  Is there some other way to get probing macros?
24 May 2025 16:52 - 24 May 2025 16:54 #329062 by theoneandonlyoreo
Replied by theoneandonlyoreo on topic problems with Verser Probe Screen 2.9
It appears that the pins in question (probe.toolchange-change, etc) would be created by probe_screen.py.
In the INI file,
EMBED_TAB_NAME=PSNG
EMBED_TAB_COMMAND=halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -u psng/python/probe_screen.py -x {XID} psng/probe_screen.glade
EMBED_TAB_LOCATION = ntb_user_tabs
And from custom_postgui.hal
# Ensure all toolchange pins are free to use
unlinkp iocontrol.0.tool-number
unlinkp iocontrol.0.tool-prep-number
unlinkp iocontrol.0.tool-change
unlinkp iocontrol.0.tool-changed
unlinkp iocontrol.0.tool-prepare
unlinkp iocontrol.0.tool-prepared
net tool-change            probe.toolchange-change      <=   iocontrol.0.tool-change
net tool-changed           probe.toolchange-changed     =>   iocontrol.0.tool-changed
net tool-number            probe.toolchange-number      <=   iocontrol.0.tool-number
net tool-prep-number       probe.toolchange-prep-number <=   iocontrol.0.tool-prep-number
net tool-prep-loopback     iocontrol.0.tool-prepare     <=   iocontrol.0.tool-prepared
net tool-prep-loop         iocontrol.0.tool-prepare      <=   iocontrol.0.tool-prepared
#loadusr -W probe_screen
loadusr -W /home/cnc/linuxcnc/configs/lycnc/psng/python/probe_screen.py
Last edit: 24 May 2025 16:54 by theoneandonlyoreo.
24 May 2025 17:30 - 24 May 2025 17:33 #329065 by Aciera
Replied by Aciera on topic problems with Verser Probe Screen 2.9
You need to remove this from your hal
You are already loading probe_screen.py with the EMBED_TAB_COMMAND in the INI.
To troubleshoot the pin problem, comment all lines with 'probe.' pins so the config starts up and use the 'Show Hal Configuration' tool to check if the pins are there.
Last edit: 24 May 2025 17:33 by Aciera.
24 May 2025 20:52 #329074 by theoneandonlyoreo
That's a good suggestion. I comment out the offending lines and looked around "Show HAL Configuration"
Turns out, probe.* pins don't exist. HOWEVER, gladevcp.* has all the pins that have been implicated, including gladevcp.toolchange-change and gladevcp.ps_probe_max
The Z-height probing routine kicks off a message complaining that probe.ps_probe_max is not available so I thought I'd try to name it at the outset. I tried using EBMED_TAB_COMMAND to adjust the component name with -c probe but that doesn't run.
I dug around some more and found a line in probe_screen.py that was commented out.
self.halcomp = hal.component( "probe" )
I un-commented it and it may have this particular problem. Makes me nervous because there are other lines nearby that are commented out...
Thanks for the tip, Aciera. Great handle, too.
25 May 2025 16:07 #329114 by andypugh
Replied by andypugh on topic problems with Verser Probe Screen 2.9
Which version of Linux, LinuxCNC and psng are you using?
I have done some work on psng to adapt it for Gtk3 / Python3 on Debian 12+
However, on my test machines, whilst it loads without errors, there are no graphics visible in the embedded tabs.
06 Sep 2025 05:03 #334529 by cadcam
Replied by cadcam on topic problems with Verser Probe Screen 2.9
Have you made any further progress with this?
06 Sep 2025 15:41 #334554 by cmorley
Replied by cmorley on topic problems with Verser Probe Screen 2.9
I'm curious, Why aren't people working on the version in linuxcnc?
github.com/LinuxCNC/linuxcnc/tree/master...n-panels/versa-probe
The following user(s) said Thank You: cadcam
09 Sep 2025 05:55 - 09 Sep 2025 08:29 #334671 by cadcam
Maybe we can combine them?
Last edit: 09 Sep 2025 08:29 by cadcam.
09 Sep 2025 14:55 #334707 by andypugh
Well, until 3 days ago it was GTK2.
I can't remember why I chose to work with a different version, except that I think I assumed that PSNG was enhanced relative to VersaProbe.
Time to create page: 0.317 seconds
