Servo tuning Step/Dir
- Sternfox
- Thank you received: 7
03 Jun 2025 18:16 #329624
by Sternfox
Servo tuning Step/Dir was created by Sternfox
Hi Guys,
I have a converted hass mini mill running 1kw Ac servos, I am using them in Step and Direction mode. At the moment, they are not feeding back into my Mesa 7i95T.
First question is there any benefit to feeding the encoder back to the controller?
And can/should I tune the PID? im at the understanding that this is only for analogue drives?
I am getting the occasional follow error, Im set at 1 and 0.5 which is really high. and im only running at 6000mm/s
Any advice would be great.
Tnanks
Tnanks
- Thank you received: 5325
03 Jun 2025 18:31 - 03 Jun 2025 18:32 #329625
Replied by PCW on topic Servo tuning Step/Dir
Typically there is not much advantage in using encoders on step/dir systems
unless you have linear scales.
If you get following errors, I would first increase this number:
setp hm2_[MESA](BOARD).0.dpll.01.timer-us -50
to:
setp hm2_[MESA](BOARD).0.dpll.01.timer-us -200
Also check that the stepgen maxaccel values have sufficient headroom
from the joint and axis maxaccel values.
The stepgen values should be at least 25% greater than the joint/axis
values if no backlash compensation is used and at least 225% of the joint/axis
values if backlash compensation is used.
Also check
hm2_7i95.0.packet-error-total
To make sure no packets are being dropped due to network timeouts.
to:
Also check
Last edit: 03 Jun 2025 18:32 by PCW. Reason: format a bit better
Time to create page: 0.319 seconds
