Solving Reversed Spindle Speed: HAL Inversion for PWM-to-Analog (Pi5, hal_gpio)
  • LucDav
  • Topic Author
  • New Member
  • New Member
1 year 4 months ago - 1 year 4 months ago #330876 by LucDav
Hello everyone,
I'm setting up a PWM-controlled spindle for my LinuxCNC machine. My analog DC motor controller requires a 0-10V input, which I'm generating with this specific PWM-to-analog converter: www.amazon.co.uk/Digital-Analog-Module-C...&smid=A2BXCFIGGD7VDT .
The PWM signal is sourced directly from a Raspberry Pi 5's GPIO, routed through our custom-designed isolator board HAT, V1.1, which you can find details about here: github.com/data124001/Isolation/wiki . We're running LinuxCNC version 2.9.1 and using the hal_gpio library.
The core issue is that this specific PWM-to-analog converter appears to invert the control signal: a 100% PWM duty cycle from the Pi (and hal_gpio) results in zero motor speed, while a 0% PWM duty cycle results in full motor speed. This means my spindle speed control is completely reversed from what's expected (higher LinuxCNC speed command = lower motor RPM).
We have confirmed that the PWM signal generated by the Raspberry Pi 5's GPIO (whether directly or via our custom isolator board) is behaving correctly in terms of duty cycle interpretation (e.g., 50% duty cycle is "half on"). However, without this specific PWM-to-analog converter in the loop, we have no meaningful 0-10V speed control for the motor controller, only basic on/off, as the raw PWM is unsuitable.
Therefore, the problem lies squarely with the inversion introduced by the Amazon PWM-to-analog converter itself when converting the standard Pi PWM.
My question is: What are the most effective and robust methods within LinuxCNC's HAL configuration to invert the hal_gpio PWM signal before it reaches this converter? I'm looking for a HAL-based software solution to achieve the correct 0-10V spindle speed control (where a higher LinuxCNC spindle.0.speed-out value corresponds to a higher analog voltage to the motor controller and thus higher motor RPM).
I will be attaching my HAL and INI files to this post to provide full context of my current setup.
Any specific HAL configurations or example code would be incredibly helpful!
Thanks in advance.
Last edit: 1 year 4 months ago by LucDav.
1 year 4 months ago #330877 by tommylight
1 No double posting
2 most VFD's can do 0-5V or 0-10V settable, see manual
3 to invert pins on LinuxCNC it is as simple as :
setp parport.0.pin-01-out-invert 1
Should be similar for RPI, but i do not use RPI so no way of confirming from my side, give it a try.
1 year 4 months ago - 1 year 4 months ago #330878 by PCW
A guess:
setp hal_gpio.pin-40-out-invert true
Running LinuxCNC and then running:
halcmd show all | grep invert
in a terminal window should give the the exact naming syntax
Last edit: 1 year 4 months ago by PCW.
Time to create page: 0.667 seconds
