Update,
I have successfully added the emergency stop button. The problem was with the Mesa 7i95 board's nomenclature used for input/output pins. I was using the wrong pin (hm2_7i95.0.gpio.000.in). The correct input 00 pin for the Mesa 7i95 board is inmux 00 pin (hm2_7i95.0.inmux.00.input-00). Below is the code added to the hal file...
net estop-out iocontrol.0.user-enable-in
net external-estop-in hm2_7i95.0.inmux.00.input-00 => iocontrol.0.emc-enable-in
The next problem is still pending about the feed override.
Thank you, Benb and PCW, for your input. You are correct that I want to control feed override using external analog voltage control (cRIO-9045, NI-9775, LabVIEW Software). I have never modified the Mesa default pin configuration, and I am trying to search for how to modify the Mesa board pin configuration. It would be great if I could use the motor or encoder pin for analog input. I request that you give me more ideas/references to do the same. As PCW suggests, "The 7I95/7I95T has no analog input, so an encoder is probably a better choice." Kindly give more hints on how to use the encoder to control the feed override using external analog voltage control (cRIO-9045, NI-9775, LabVIEW Software)
Another idea I am thinking about is serial communication using the serial port available in the Mesa board; there are two serial communication ports (serial 1, serial 2). But at the moment no idea how to do this as well.
Another thing I was trying to identify was the pin/parameter that is responsible for feed override. In Axis GUI, there is a button for feed override, but I am not able to locate the corresponding pin and parameter in the Halshow Configuration window. I do locate one pin, but it is saying it is not writable. A screenshot is attached.
