Adding external switch for emergency stop and feed override
9 months 4 days ago #342129 by suraj9735
Hello PCW,
Can you explain more wiring of encoder pin of 7i95 with analog voltage supply from LabVIEW hardware. In my knowledge, encoder pin of 7i95 is a digital pin and we can not connect with an analog input power supply pin?
I am ok with buying a new 7i73 daughter card if this is not possible with 7i95 card alone. Give some more guidance on how to connect 7i73 card with 7i95 card and the piece of code need to be written in .ini and .hal file
Time to create page: 0.238 seconds
