Manual home to a specific location
26 Jul 2025 22:44 #332381 by LoneWolfQuest
Manual home to a specific location was created by LoneWolfQuest
I would like to find out how to tell LinuxCNC in absolute terms that your position is x,y,z.
Not relative. I want to set the actual position of x,y.z.
I do not have limit switches to home.
I manually home to a custom jig at the center of the machine.
After I do this, I need to tell LinuxCNC "you are here".
Everything I've tried creates a corresponding negative relative offset.
Please help, and thanks in advance.
--LoneWolf.Quest
27 Jul 2025 00:24 #332388 by tommylight
Replied by tommylight on topic Manual home to a specific location
Picture? Drawing? anything that would help explain what you're trying to achieve.
If you are comfortable editing the ini file, try changing HOME_OFFSET and HOME, see if it works for you.
Time to create page: 3.034 seconds
