Warning before homing?
  • TheTinkeringMechanic1
  • Senior Member
  • Senior Member
05 Aug 2025 10:59 #332876 by TheTinkeringMechanic1
Warning before homing? was created by TheTinkeringMechanic1
Is it possible to have a "ok" confirmation warning pop after pressing any of the homing buttons in the GUI?
Something like:
"Ensure no rollers are installed before homing axis!"
                                 Ok
05 Aug 2025 12:11 #332880 by andypugh
Replied by andypugh on topic Warning before homing?
I think that this would best be done in the GUI.
Which GUI are you using?
You _could_ use the "message" component to pop up the message when any HAL pin indicates "homing" but blocking the homing until the OK button is pressed would be harder.
linuxcnc.org/docs/stable/html/man/man9/message.9.html
A custom python component might be able to monitor homing state, pop up the message and also inhibit motion until OK is pressed.
I don't know if set_feed_hold or maxvel affect homing moves.
linuxcnc.org/docs/stable/html/config/pyt...command_code_methods
  • Senior Member
  • Senior Member
05 Aug 2025 16:02 #332903 by TheTinkeringMechanic1
Replied by TheTinkeringMechanic1 on topic Warning before homing?
Thank you. I will look into this. I'll post what version of GUI I'm using when I can.
  • Senior Member
  • Senior Member
05 Aug 2025 19:25 #332911 by TheTinkeringMechanic1
Gmoccapy for Linuxcnc 3.4.6
08 Aug 2025 20:19 #333066 by andypugh
Gmoccapy is written in Python, you might want to look at just adding some more code. If you know Python, that is.
Time to create page: 1.738 seconds
