Absoluted Encoder but Move the G53 Origin
- CTB_le123
20 Aug 2025 03:27 #333709
by CTB_le123
Absoluted Encoder but Move the G53 Origin was created by CTB_le123
Hey, I need some help.
I have configured a machine using LinuxCNC, and the joints are equipped with absolute encoders. Now, I want to achieve the following: Point A is the zero-count position of the encoder, but I would like to set Point B, which is offset 200mm from Point A, as the G53 origin. How should I configure this?
Here is my ini configure:
[JOINT_1]
TYPE = LINEAR
MAX_VELOCITY = 1200
MAX_ACCELERATION = 2000
# MIN_LIMIT = -10.0
# MAX_LIMIT = 10.0
HOME = -10
HOME_ABSOLUTE_ENCODER = 2
HOME_OFFSET = 35
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_IGNORE_LIMITS = NO
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
VOLATILE_HOME = 0
But the problem is when I homing the axis, the joint->motor_pos_cmd whill change suddenly. which cause the joint move suddenly. It is particularly dangerous.
Thank you for ur help!
[JOINT_1]
TYPE = LINEAR
MAX_VELOCITY = 1200
# MIN_LIMIT = -10.0
# MAX_LIMIT = 10.0
HOME = -10
HOME_OFFSET = 35
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
VOLATILE_HOME = 0
- Thank you received: 4648
20 Aug 2025 12:10 - 20 Aug 2025 12:12 #333734
Replied by andypugh on topic Absoluted Encoder but Move the G53 Origin
I think that HOME_OFFSET is the parameter that controls this. (you probably want to make HOME and HOME_OFFSET the same, or possibly one the inverse of the other)
Last edit: 20 Aug 2025 12:12 by andypugh.
- CTB_le123
21 Aug 2025 01:31 #333742
by CTB_le123
Replied by CTB_le123 on topic Absoluted Encoder but Move the G53 Origin
I modified the homing.c to get it.
23 Aug 2025 09:36 #333793
If you want to make this “stick” through upgrades then note that you can define your own custom homing module. ((This may be what you did)
linuxcnc.org/docs/html/man/man9/homecomp.9.html
Time to create page: 1.277 seconds
