RPi5 Scale settings
- krille
- Topic Author
1 year 1 month ago #335195
by krille
RPi5 Scale settings was created by krille
Hi I has problem with my setup ini file I do not understand the behavior of this if I use 200 step for the scale in my z axle and then G0Z-100 and the movment stop at 40 mm
step 300 = 60 mm
step 400 = 81mm
step 500 = 78 mm
step 600 = 59 mm
Why can´'t I hit 100 mm in my set up I tryed many diferent value of steps with 50 increasment
computer = Raspberry Pi 5 ,breakoutboard db25 cinese make , stepperdriver DM542 , 1/4 800 steps , motors 200 steps
are there any kind to help me in the right direction
yours sinserly Krister
step 300 = 60 mm
step 400 = 81mm
step 500 = 78 mm
step 600 = 59 mm
- Thank you received: 5334
1 year 1 month ago #335198
Replied by PCW on topic RPi5 Scale settings
Are you sure it is not stalling because your accel/velocity values are too high?
if the distance moved with a 100 mm command is not inversely proportional
to the scale, the hardware is not following the command.
500 mm/s is way faster than is possible.
Even at 300 steps per mm, 500 mm/s needs a 150 KHz step rate, but your base thread
period limits you to only about 5KHz (5 KHz = about 16.6 mm/sec at 300 steps/mm)
- krille
- Topic Author
1 year 1 month ago #335201
by krille
Replied by krille on topic RPi5 Scale settings
I try tomorow a lower speed . Thank you very much for a quick replay
Time to create page: 0.046 seconds
