Wrapped Rotary on Non Rotary Axis Letter.
- jschulze
- Thank you received: 14
I also have the rotary table setup as a second axis and what I would like to ultimately do is setup the rotary table to wrap the axis position at 360 and also keep track of the position while using it as a spindle. Right now I just use a generic mux2 to switch the joint velocity between W axis velocity and spindle 1 velocity signals using the spindle.1.on and it works great, but I'm not sure how to keep the axis position when it's in spindle mode. I'm using step/dir servos to drive the table, so I don't have an encoder on the table output itself. Is there a way to fake an encoder signal from the spindle output to feedback into the joint position?
- jschulze
Not sure. Either way it's not working for me and I'm not sure why. It works no problem as a rotary axis, but I'd like to figure out a way to keep position while using it as a spindle and I figure that will be easier if it wraps at 360.Does the letter matter?
Isn't it just a visual ID?
- Thank you received: 2164
~/git/linuxcnc-dev$ grep -rnw ./ -e WRAPPED_ROTARY
./configs/sim/axis/wrapped_rotary/wrapped_rotary.ini:85:WRAPPED_ROTARY = 1
./bin/axis:3516:a_axis_wrapped = inifile.find("AXIS_A", "WRAPPED_ROTARY")
./bin/axis:3517:b_axis_wrapped = inifile.find("AXIS_B", "WRAPPED_ROTARY")
./bin/axis:3518:c_axis_wrapped = inifile.find("AXIS_C", "WRAPPED_ROTARY")
./src/emc/rs274ngc/rs274ngc_pre.cc:872: inifile.Find(&_setup.a_axis_wrapped, "WRAPPED_ROTARY", "AXIS_A");
./src/emc/rs274ngc/rs274ngc_pre.cc:873: inifile.Find(&_setup.b_axis_wrapped, "WRAPPED_ROTARY", "AXIS_B");
./src/emc/rs274ngc/rs274ngc_pre.cc:874: inifile.Find(&_setup.c_axis_wrapped, "WRAPPED_ROTARY", "AXIS_C");
./src/emc/usr_intf/axis/scripts/axis.py:3514:a_axis_wrapped = inifile.find("AXIS_A", "WRAPPED_ROTARY")
./src/emc/usr_intf/axis/scripts/axis.py:3515:b_axis_wrapped = inifile.find("AXIS_B", "WRAPPED_ROTARY")
./src/emc/usr_intf/axis/scripts/axis.py:3516:c_axis_wrapped = inifile.find("AXIS_C", "WRAPPED_ROTARY")
./src/emc/usr_intf/gremlin/qt5_graphics.py:274: self.a_axis_wrapped = self.inifile.find("AXIS_A", "WRAPPED_ROTARY")
./src/emc/usr_intf/gremlin/qt5_graphics.py:275: self.b_axis_wrapped = self.inifile.find("AXIS_B", "WRAPPED_ROTARY")
./src/emc/usr_intf/gremlin/qt5_graphics.py:276: self.c_axis_wrapped = self.inifile.find("AXIS_C", "WRAPPED_ROTARY")
./src/emc/usr_intf/gremlin/gremlin.py:204: self.a_axis_wrapped = inifile.find("AXIS_A", "WRAPPED_ROTARY")
./src/emc/usr_intf/gremlin/gremlin.py:205: self.b_axis_wrapped = inifile.find("AXIS_B", "WRAPPED_ROTARY")
./src/emc/usr_intf/gremlin/gremlin.py:206: self.c_axis_wrapped = inifile.find("AXIS_C", "WRAPPED_ROTARY")
grep: ./src/objects/emc/rs274ngc/rs274ngc_pre.o: binary file matches
./docs/src/config/ini-config.adoc:902:* `WRAPPED_ROTARY = 1` - When this is set to 1 for an ANGULAR axis the axis will move 0-359.999 degrees.
grep: ./lib/librs274.so.0: binary file matches
./lib/python/qt5_graphics.py:274: self.a_axis_wrapped = self.inifile.find("AXIS_A", "WRAPPED_ROTARY")
./lib/python/qt5_graphics.py:275: self.b_axis_wrapped = self.inifile.find("AXIS_B", "WRAPPED_ROTARY")
./lib/python/qt5_graphics.py:276: self.c_axis_wrapped = self.inifile.find("AXIS_C", "WRAPPED_ROTARY")
./lib/python/gremlin.py:204: self.a_axis_wrapped = inifile.find("AXIS_A", "WRAPPED_ROTARY")
./lib/python/gremlin.py:205: self.b_axis_wrapped = inifile.find("AXIS_B", "WRAPPED_ROTARY")
./lib/python/gremlin.py:206: self.c_axis_wrapped = inifile.find("AXIS_C", "WRAPPED_ROTARY")Please Log in or Create an account to join the conversation.
- jschulze
Thanks so much for checking. I'll try to figure out a different solution.Looking for 'WRAPPED_ROTARY' in the source code seems to suggest that it indeed only applies to axes A,B,C:
~/git/linuxcnc-dev$ grep -rnw ./ -e WRAPPED_ROTARY ./configs/sim/axis/wrapped_rotary/wrapped_rotary.ini:85:WRAPPED_ROTARY = 1 ./bin/axis:3516:a_axis_wrapped = inifile.find("AXIS_A", "WRAPPED_ROTARY") ./bin/axis:3517:b_axis_wrapped = inifile.find("AXIS_B", "WRAPPED_ROTARY") ./bin/axis:3518:c_axis_wrapped = inifile.find("AXIS_C", "WRAPPED_ROTARY") ./src/emc/rs274ngc/rs274ngc_pre.cc:872: inifile.Find(&_setup.a_axis_wrapped, "WRAPPED_ROTARY", "AXIS_A"); ./src/emc/rs274ngc/rs274ngc_pre.cc:873: inifile.Find(&_setup.b_axis_wrapped, "WRAPPED_ROTARY", "AXIS_B"); ./src/emc/rs274ngc/rs274ngc_pre.cc:874: inifile.Find(&_setup.c_axis_wrapped, "WRAPPED_ROTARY", "AXIS_C"); ./src/emc/usr_intf/axis/scripts/axis.py:3514:a_axis_wrapped = inifile.find("AXIS_A", "WRAPPED_ROTARY") ./src/emc/usr_intf/axis/scripts/axis.py:3515:b_axis_wrapped = inifile.find("AXIS_B", "WRAPPED_ROTARY") ./src/emc/usr_intf/axis/scripts/axis.py:3516:c_axis_wrapped = inifile.find("AXIS_C", "WRAPPED_ROTARY") ./src/emc/usr_intf/gremlin/qt5_graphics.py:274: self.a_axis_wrapped = self.inifile.find("AXIS_A", "WRAPPED_ROTARY") ./src/emc/usr_intf/gremlin/qt5_graphics.py:275: self.b_axis_wrapped = self.inifile.find("AXIS_B", "WRAPPED_ROTARY") ./src/emc/usr_intf/gremlin/qt5_graphics.py:276: self.c_axis_wrapped = self.inifile.find("AXIS_C", "WRAPPED_ROTARY") ./src/emc/usr_intf/gremlin/gremlin.py:204: self.a_axis_wrapped = inifile.find("AXIS_A", "WRAPPED_ROTARY") ./src/emc/usr_intf/gremlin/gremlin.py:205: self.b_axis_wrapped = inifile.find("AXIS_B", "WRAPPED_ROTARY") ./src/emc/usr_intf/gremlin/gremlin.py:206: self.c_axis_wrapped = inifile.find("AXIS_C", "WRAPPED_ROTARY") grep: ./src/objects/emc/rs274ngc/rs274ngc_pre.o: binary file matches ./docs/src/config/ini-config.adoc:902:* `WRAPPED_ROTARY = 1` - When this is set to 1 for an ANGULAR axis the axis will move 0-359.999 degrees. grep: ./lib/librs274.so.0: binary file matches ./lib/python/qt5_graphics.py:274: self.a_axis_wrapped = self.inifile.find("AXIS_A", "WRAPPED_ROTARY") ./lib/python/qt5_graphics.py:275: self.b_axis_wrapped = self.inifile.find("AXIS_B", "WRAPPED_ROTARY") ./lib/python/qt5_graphics.py:276: self.c_axis_wrapped = self.inifile.find("AXIS_C", "WRAPPED_ROTARY") ./lib/python/gremlin.py:204: self.a_axis_wrapped = inifile.find("AXIS_A", "WRAPPED_ROTARY") ./lib/python/gremlin.py:205: self.b_axis_wrapped = inifile.find("AXIS_B", "WRAPPED_ROTARY") ./lib/python/gremlin.py:206: self.c_axis_wrapped = inifile.find("AXIS_C", "WRAPPED_ROTARY")
- jschulze
I'm using XYZACW. It's a router with an CA style head. The W axis is an additional "C" axis rotary table, but I didn't want to use B because the kinematics file I'm using for TCP has a B axis and I don't know how to mess with the kinematic enough to make it ignore the B axis commands.What axes does your setup have?
Perhaps having unlimited "WRAPPED_ROTARY" axes on any axis letter is a feature should be added to the source code.
- jschulze
I use a Mesa 7i76eu with ethernet. I'm guessing with a little trial and error I could modify the kinematics file to just set the B axis value to a constant 0 to avoid it being in the calculations for TCP and then passthrough the actual value to my joint. The actual matrix math stuff is well beyond my level, so I'd rather leave that alone. Not totally sure I'd want to label it B axis instead of W anyway, since B wraps around Y in my head.Hmm...
There must be a solution so your setup can be XYZABC.
How does the PC communicate with the machine?
I'm going to work a bit on trying to get the axis to retain position values when it's in spindle mode, I'm using a step/dir servo, so I need to figure out a way to keep track of position somehow.
- jschulze
Yeah, I'm really glad Aciera put in all of the hard work to get it all working, otherwise I'd never be able to get TCP or TWP working myself.I am impoving a Java macro program called Repeat that uses matrices to identify mouse gestures; it works, but I have absolutely no idea how or why it works.
