Servo and encoder setup issue
03 Oct 2025 20:12 #335795 by vibram
Servo and encoder setup issue was created by vibram
Hello
I'm loosing my mind on my setup.
Right now, I'm only focused on the X axis so don't pay attention to other axis/joint.
here is my issue:
When jogging, when i press 2 times X+ with 1mm step, the first step moves, the second I have a joint 0 following error.
In HAL show, the first issue I see is the encoder going negative when I press X+.
I tried to setup the output_scale at -1 instead of 1, still the same issue. same for input_scale and encoder_scale.
I tried to put everything negative but my counter always go the same direction.
Do you have any idea please?
If you find something else wrong with my X/joint0 setup do not hesitate. Only the BIAIS works well right now
Thanks a lot
File Name: custom_2025-10-03.hal
File Size:0 KB
File Name: mill2.ini
File Size:3 KB
File Name: mill2.hal
File Size:11 KB
03 Oct 2025 21:28 - 03 Oct 2025 21:28 #335796 by PCW
Replied by PCW on topic Servo and encoder setup issue
Note that ENCODER_SCALE does nothing as it's not used in the hal file
(same with INPUT_SCALE)
Is there an alternate way to set the scale on the EL5101?
If not, feeding the encoder count through the scale component
(after the S32-->float conversion) would allow scaling/sign change.
Last edit: 03 Oct 2025 21:28 by PCW.
04 Oct 2025 12:49 - 04 Oct 2025 12:50 #335811 by vibram
Replied by vibram on topic Servo and encoder setup issue
thank you as always for your help.
I managed to reverse the encoder scale correctly
I must have something wrong with my closed loop signal
If I jog, on the first order; my pid.x.command is stuck and don't go back to 0. don't pay attention to the enc-count, this is before the *-1 scale
File Name: custom_2025-10-04.hal
File Size:0 KB
File Name: mill2_2025-10-04.ini
File Size:3 KB
File Name: mill2_2025-10-04.hal
File Size:11 KB
Last edit: 04 Oct 2025 12:50 by vibram.
Time to create page: 0.223 seconds
