Is there any reason to set the values for pins / parameters in the INI vs. the HAL? Is using the INI simply a best practice?
For example, this line are in the HAL file:
setp pid.u.Pgain [JOINT_4]P
and this in in the INI file
P = 1000.0
I assume I could set this value in the HAL file without using the INI file:
setp pid.u.Pgain 1000.0
