StepConf setup of Z-Axis Home and Limit switch
- JasonS
27 Oct 2025 02:58 - 27 Oct 2025 03:30 #337262
by JasonS
StepConf setup of Z-Axis Home and Limit switch was created by JasonS
I'm refreshing / updating a minimill I built back in 2010. It's been idle for probably 12 years or so, and I decided to dust it off and see if it still worked (and if I remembered anything at all about it!). This was partially prompted because I learned that maybe FreeCad could generate tool paths...? (unconfirmed, but I think hearing that is what piqued my interest again.)
Anyway, it's an old beast - I've installed a new disk and installed the latest linuxcnc I could download, set up the RTAI kernel (I'm using a parallel port, not a Mesa board - for now at least, and my latencies were sometimes getting up above 100 nS).
Sorry, that's all just context - the point: My home / limit switch is not working for my Z-Axis. Mind you, electrically it works - I had it operating under the old OS / EMC2 before upgrading, and I've confirmed with a voltmeter that it's getting a 5v signal, and the switch opens when I push it. But when I push it, I see no indication in LinuxCNC that limit has been hit.
This was discovered right after running through the StepConf wizard. I looked around a bit, and saw that StepConf had written "max-home-u" instead of the expected (by me) "max-home-z" into my .hal file. For x & y, it had written "min-home-x" and "min-home-y".
So, I double-checked that I'd selected the right entry in stepconf wizard (I had), and tried again. Same. In fact, the error even existed in the .stepconf file:
<property type="string" name="pin12" value="max-home-u"/> <!-- Jason: Should be max-home-z instead, and that's essentially what was shown in the UI. -->
So, I manually changed the entry in the hal file to say the max-home-z value that I expect is correct. I also saw that max-home-z was already present in another part of the file (where that value is 'mapped' to the limit and the home inputs.). EDIT : When I came back to add detail and attachments, I couldn't confirm this - I swear I saw it before, but maybe I was actually looking at the info for the X or Y axis. I can't find it for Z now. That's my leading suspect at the moment, now!
net max-home-u <= parport.0.pin-12-in-not
became
net max-home-z <= parport.0.pin-12-in-not
I restarted linuxcnc, and that didn't fix it. I restarted the whole computer, and it still didn't fix it. I'm at a bit of a loss.
I did a lot of searching, and my AI sidekick told me I'd found a known issue in StepConf Wizard, but I don't actually see much confirmation of that in reality. I did find this thread (forum.linuxcnc.org/49-basic-configuratio...is-homing-and-travel) so I suspect it at least one person before has been affected by it. Unfortunately, I didn't see any indication that that issue was ever really resolved.
I guess you'll like to see my .hal and .ini files, if you are inclined to look into this at all (helpful unknown reader!), so, I'll attach them as soon as I have them handy. I'm walking back and forth to do everything now, because that computer is too uncomfortable to sit and type at for any stretch, and I don't have SSH working yet.
Thanks!
Jason
became
Thanks!
Jason
Last edit: 27 Oct 2025 03:30 by JasonS. Reason: Edited to add a bit more detail, and attach the files once I had them handy, and my SSH working. I will now test to see if my suspicion about the was correct.
- JasonS
27 Oct 2025 04:25 #337266
by JasonS
Replied by JasonS on topic StepConf setup of Z-Axis Home and Limit switch
This was a case of needing to really dig into it "one more time" - The problem I was facing (and just couldn't see until I was documenting it all for 'You', was that the following section was also missing from my hal file:
net max-home-z => joint.2.home-sw-in
net max-home-z => joint.2.neg-lim-sw-in
At some point in the process, I thought I saw it - I don't know if I misread it (seeing either the X or Y version) or if I somehow accidentally deleted it right after seeing it, but putting it in allowed the home switch to work, and now the mill is one step closer to working.
I am having some teething issues with getting Z set up nicely (why is Z always the complicated one!?), but I think I'll get that sorted out soon enough once I dig into it tomorrow.
Although this is resolved already, I'll just leave it out here for the benefit of anyone else searching for help on this problem.
Time to create page: 0.069 seconds
