Motor Driver Electrical Question
11 months 4 weeks ago #337790 by gardenweazel
As always, thanks to all for your valuable feedback.
11 months 4 weeks ago #337793 by unknown
The reason I mentioned the 48V not being necessarily ideal is some electronics are made with almost zero headroom above their limits.
For example, I own a 12V DELTA power supply that can be adjusted to output 14VDC; however, its filter caps are only rated for 16V!
That's 2V of headroom!
Which is absolutely fine, that is the way the designers intended.
Discussion on voltage values
www.eevblog.com/forum/beginners/is-there...igher-rated-voltage/
The following user(s) said Thank You: gardenweazel
11 months 2 weeks ago #338574 by gardenweazel
Confirming that the 3.8A is a comfortable setting and additionally lowered the heat of the motors.
Thank to everyone that provided feedback!
Time to create page: 0.092 seconds
