First Machine, can't get 6i25 to drive CL57Y/CL86Y
16 Nov 2025 22:53 #338543 by Autumn Reign
I've been working on a large format gantry cnc for a few months now and while I have plenty of mechanical design experience and a decent bit of controls, LinuxCNC and this style of hardware is well outside of my (current) comfort zone. I've got my HAL/ini files loading into LinuxCNC without error, and am starting to get the hang of syntax and method for this kind of machine control, but I've got some pretty glaring rookie issues left to sort.
I can power up the mesa board and actuate my steppers with mechanical switches on the 5v and 0v outputs, so my machine wiring is functional and my driver is not fried or otherwise inoperable. I am using 5v on PU+ for power input and then grounding PU- on my z axis stepgen on pin 7, starting the pin count from 0. I have inverted the pin with setp   hm2_5i25.0.gpio.007.invert_output true in my hal and the pin reads 5V when idle so I think I have everything right up to that point. However, nothing moves when homing or jogging a joint, and when I let the home run I see no activity with a multimeter on the pin. I feel like I am doing something dumb and unless I can find a solution I'll go get some daughter cards for the 6i25. For several reasons none of the standard offering quite fit my needs but I can make some combination work.
Any advice? I've called into Mesa twice and have been able to make a lot of headway from the info gained there to even get to this point but this is where I am starting to stumble. I feel like I am missing something on timing or tuning obvious in retrospect. Files attached.
17 Nov 2025 00:38 - 17 Nov 2025 00:57 #338546 by PCW
What firmware are you using?
sudo mesaflash --device 5i25 --readhmid
Will print the pinout of the currently installed firmware
( assuming you are using the 5abob firmware, DB25 pin 7 is stepgen 2 DIR, not STEP )
Last edit: 17 Nov 2025 00:57 by PCW.
17 Nov 2025 00:45 #338548 by Autumn Reign
Replied by Autumn Reign on topic First Machine, can't get 6i25 to drive CL57Y/CL86Y
2.9.7, Preempt rt ISO
Stepper online, no clones.
axis
The drivers, CLXX's no daughters.
I think the problem being between the 6i25 and the drivers is probable.
I tried some weak oscilloscopes. Nothing better than AC multimeters, it just read gibberish. I really should get a good one as a work expense. Something that can ID freq bands. I could go that route if this SHOULD work.
17 Nov 2025 00:56 #338549 by Autumn Reign
I believe it's Bob if I did the flash right. I'm still not 100% on how all these talk and write to one another. I'll run the readhmid after I am done making dinner.
I'm not sure if this nomenclature starts at 0 or 1. It's physically the 8th pin starting from 1 which is how I understand DB25 to be counted by, but the config starts joints from 0 and I'm not sure how to describe the count due to that.
17 Nov 2025 01:05 #338550 by PCW
On the 6I25/5I25 mesaflash lists DB25 pin numbers
DB25 connectors are numbered:
1    2    3    4    5    6    7    8    9    10    11    12    13
  14  15  16  17  18 19  20  21  22    23     24    25
Also you don't need to use GPIO to invert step or dir pins, there are aliased names like:
hm2_5i25.0.stepgen.00.direction.invert_output
hm2_5i25.0.stepgen.00.step.invert_output
17 Nov 2025 01:38 #338554 by Autumn Reign
I read a few posts that you said on this but it failed to compile when launching linuxcnc when I used that stepgen/invert nomenclature. Past posts included 1 or TRUE in the definition, I will try the above verbatim.
17 Nov 2025 01:49 #338555 by Autumn Reign
BoardName : MESA5I25
FPGA Size: 9 KGates5
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
There are 2 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: StepGen
There are 10 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 0 IOPort StepGen 0 Dir/Table2 (Out)
14 1 IOPort StepGen 0 Step/Table1 (Out)
2 2 IOPort StepGen 1 Dir/Table2 (Out)
15 3 IOPort StepGen 1 Step/Table1 (Out)
3 4 IOPort StepGen 2 Dir/Table2 (Out)
16 5 IOPort StepGen 2 Step/Table1 (Out)
4 6 IOPort StepGen 3 Dir/Table2 (Out)
17 7 IOPort StepGen 3 Step/Table1 (Out)
5 8 IOPort StepGen 4 Dir/Table2 (Out)
6 9 IOPort StepGen 4 Step/Table1 (Out)
7 10 IOPort SSerial 0 TXData0 (Out)
8 11 IOPort SSerial 0 RXData0 (In)
9 12 IOPort SSerial 0 TXData1 (Out)
10 13 IOPort SSerial 0 RXData1 (In)
11 14 IOPort QCount 0 Quad-IDX (In)
12 15 IOPort QCount 0 Quad-B (In)
13 16 IOPort QCount 0 Quad-A (In)
IO Connections for P2
1 17 IOPort StepGen 5 Dir/Table2 (Out)
14 18 IOPort StepGen 5 Step/Table1 (Out)
2 19 IOPort StepGen 6 Dir/Table2 (Out)
15 20 IOPort StepGen 6 Step/Table1 (Out)
3 21 IOPort StepGen 7 Dir/Table2 (Out)
16 22 IOPort StepGen 7 Step/Table1 (Out)
4 23 IOPort StepGen 8 Dir/Table2 (Out)
17 24 IOPort StepGen 8 Step/Table1 (Out)
5 25 IOPort StepGen 9 Dir/Table2 (Out)
6 26 IOPort StepGen 9 Step/Table1 (Out)
7 27 IOPort SSerial 0 TXData2 (Out)
8 28 IOPort SSerial 0 RXData2 (In)
9 29 IOPort SSerial 0 TXData3 (Out)
10 30 IOPort SSerial 0 RXData3 (In)
11 31 IOPort QCount 1 Quad-IDX (In)
12 32 IOPort QCount 1 Quad-B (In)
13 33 IOPort QCount 1 Quad-A
When using:
setp hm2_5i25.0.stepgen.03.direction.invert_output
setp hm2_5i25.0.stepgen.03.step.invert_output
Results:
Debug file information:
Note: Using POSIX realtime
./Autumn.hal:240: setp requires 2 arguments, 1 given
12304
Stopping realtime threads
Unloading hal components
RTAPI_PCI: Unmapped 65536 bytes at 0x7f370745c000
But:
setp hm2_5i25.0.stepgen.03.direction.invert_output TRUE
setp hm2_5i25.0.stepgen.03.step.invert_output TRUE
Executes and launches
17 Nov 2025 04:06 #338559 by PCW
Note that that is the default (as shipped) firmware, not the 5ABOB firmware
17 Nov 2025 21:42 #338583 by Autumn Reign
Yeah. Reviewing my notes its 5i25_7i76x2.
I think I just got something to click looking at these with fresh ideas. on Pncconf under the "Num" column that's not the DB25 pin, but IO number, so when I have my config configured for 7i76x2 and I want I/O 7 for Z Axis Stepgen, my joint3, that's actually Pin 17 on the DB25... I totally thought it was all mapped 1 to 1.
17 Nov 2025 21:47 #338584 by Autumn Reign
Yep. That was it. God I do not feel bright. Thanks for the help on this.
Time to create page: 0.106 seconds
