No speed control on xhc-wb04b-6 pendant on 3 axis router
  • jameslc15
  • Topic Author
  • New Member
  • New Member
10 months 1 week ago #340517 by jameslc15
Hello all
I installed a 0-10v signal from my MESA 7i77 board to the vfd to control rpm and my XHC-W04B-6 pendant will enable the spindle but wont tell the spindle to turn at default spindle speed set in the ini file .  Any help would be appreciated.
Regards
James
  • Moderator
  • Moderator
10 months 1 week ago #340539 by tommylight
A friendly warning, Mesa 7i77 can output negative voltages up to -10V, and most VFD's will complain about it vigorously and sometimes with smoke signals, so it would be advisable to wait for someone more experienced on how to limit the Mesa output going negative by probably editing the hal file and/or even using ABS component.
The following user(s) said Thank You: NWE
10 months 1 week ago - 10 months 1 week ago #340540 by NWE
and sometimes with smoke signals...
Ouch! been there done that. I'm still amazed a 10mA signal could smoke like that.
Last edit: 10 months 1 week ago by NWE.
  • Moderator
  • Moderator
10 months 1 week ago #340542 by tommylight
[/quote]
It is enough to start a chain reaction, same as throwing a wrench on any complicated machinery, no matter how small.
As for the subject, i used a Mesa 7i77 to drive a car power amplifier as a servo drive, so i had to limit voltage from going above +-2V and it worked pretty good, given the limited current those amplifiers can deliver (it will trigger over current on any faster move), but i forgot how i did the limiting in hal, pretty sure it was the MAX and MIN OUTPUT set to 2, but fuzzy on what else.
I also did 0 to +5V and it also worked, but tried with those arduino PWM drives and that did not work as analog and PWM are not the same, you can do analog from PWM easily with an RC, but not vice versa.
This was probably 10 or more years ago...
  • jameslc15
  • Topic Author
  • New Member
  • New Member
10 months 1 week ago - 10 months 1 week ago #340615 by jameslc15
Hi Tommy
Thank you for the heads up, I did some reading prior to get the vfd signal going and did hear to other peoples warnings on this forum so I've got an abs component running successfully. The issue is the pendant won't send rpm signal to analogue output 5 were as axis will ?
Last edit: 10 months 1 week ago by jameslc15.
  • Moderator
  • Moderator
10 months 1 week ago #340619 by tommylight
Usually due to naming errors, like spindle.enable should be spindle.0.enable, axis should be joints, etc.
Time to create page: 0.052 seconds
